Placa alimentacion 2300keg031a-f
  • PALOMETE
    • Nov 2012
    • ESPAÑA
    Necesito esquema de placa de alimentación codigo 2300KEG031A-F , de pantalla LCD PHILIPS Modelo 42PFL-7603D/12 , creo que también podria valer codigo DPS-279 BP , pero no estoy seguro si valdria , a lo mejor son iguales y el esquema también .
    gracias a todos .
    un saludo amigos .
  • capkid
    • Oct 2010
    • 1339
    Re: Placa alimentacion 2300keg031a-f
    Aqui esta el esquema: https://cdn.badcaps-static.com/pdfs/...f976da8b08.pdf
    Tal vez esto le ayuda como pista:
    http://www.ohmsupplies.co.uk/REPAIR-...L7603-CLICKING
    LG Plasma Mal-Discharge Correction Service
    • Allandkdk
      Schematic de asus E1404F placa HSB J 94V-0 2335 E89382
      by Allandkdk
      hola nesecito schematic de asus E1404F placa HSB J 94V-0 2335 E89382
      11-02-2024, 10:52 AM
    • Leandro Javier Ioele
      Exo Smart XL4-H3548 - Placa madre XU133U REV. 7.2.
      by Leandro Javier Ioele
      Hi colleagues, today I'm here to discuss a topic. I'm hoping to see what you guys can recommend, or rather, how you would carry out this repair...
      This is an Exo Smart XL4 laptop, with the XU133U REV 7.2 motherboard.
      A customer brought it to me because it suddenly stopped recognizing his HDD. What happens is you turn on the computer and this screen appears:
      The first thing I did was test the HDD on another machine, and obviously it worked perfectly. However, I tried other drives on the motherboard, and it still didn't recognize them.
      04-23-2025, 10:05 AM
    • Alexandre666
      Preciso do Esquema LenovoThinkcentre m90p 71y5974
      by Alexandre666
      LenovoThinkcentre m90p 71y5974 placa liga porem não gera imagem . A bobina L51 não tem nenhuma voltagem. Mosfet 145 que envia tensão para a bobina L51 está recebendo voltagem normal no dreno,porém não está chegando alimentação no gate para chavear,se alguem ja tiver tido um defeito desse e poder ajudar ficarei grato
      12-13-2023, 07:46 AM
    • Luna azul
      Esquema dell inspiron E3421
      by Luna azul
      My laptop only turns on LED charging light when I connect the charger but it does not turn on,: gtfo:
      01-31-2021, 06:55 PM
    • mximiliandz
      help bios lenovo ideapad s145-14iil type 81w6
      by mximiliandz
      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
      06-20-2025, 06:50 AM
