Problem with Samsung LN52A550P3FXZA
  • stacysturges
    • Dec 2024
    I'm experiencing an issue with my Samsung LN52A550P3FXZA. Upon powering it up, I initially see a ghosting effect in the background along with some slight red pixelation in certain areas. This then shifts to green pixelation in the black areas. The picture quality fluctuates with noise for about the first thirty minutes before it eventually clears up. I suspect the T-con board might be the culprit, but I'm also concerned that there could be a problem related to my previous repair. When I turn it on, I hear a click, and the red LED light flashes three times before the screen comes on.
    Any advice is appreciated!
    slope game
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    Same old, very old problem, you have to change the chip called as15 or as19 on the tcon boards, or even try to resolder it with total old tin removing (this is my personal suspect, never tried), needs skills of smd soldering, tons of yt videos about that chip.. bye
      09-07-2024, 05:50 AM
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • alro7779
      Samsung UN55MU6103F video problem; has colored stripes on the display
      by alro7779
      Hello, everyone!
      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
      09-27-2025, 11:29 PM
      09-06-2024, 11:40 PM
