Samsung UE50AU7172UX
  • porfyriadhs
    • Oct 2023
    • 80
    • Greece
    Hello I change the mainboard but the colors are like that. Anyone know why?
  • porfyriadhs
    • Oct 2023
    • 80
    • Greece
    • lotas
      • Jan 2016
      • 4845
      • Russia
      Most likely the T-con firmware and settings in the service menu do not match your panel...
      • porfyriadhs
        • Oct 2023
        • 80
        • Greece
        So what I will have to do. I already change Front color from service menu in option settings, but I dont know what else to do
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • Nairolf
          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
          by Nairolf
          I have a Samsung DM32D display.
          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
          Here’s what I have tried so far:
          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
          From these tests, I suspect the problem might be on the mainboard. Could anyone...
          08-24-2025, 03:47 AM
        • bohaboha
          ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
          by bohaboha
          Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
          04-19-2025, 01:47 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
