Problem with Samsung LE26R87BD
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    OK guys another Samsung another problem. i had this LE26R87BD and LE32R87BD come in at the same time both having the same problem of not responding when trying to switch on. i was sure i had a tv like this before so looked back on my threads and found out i did. i replaced what i did before on both the tvs. the 32" version went on without a hitch but the 26" version is still not responding, took out the mainboard from the 32" and placed it in the 26" an it switched on no problem, i have the discovered the panel on the 32" is bad and thus was wondering if i could keep the 32" board in the 26" tv or will this be a problem ?
    Re: Problem with Samsung LE26R87BD
    You should have no trouble, but you might want to access the service menu and check the panel size option is set right for the 26". e.g. for a Samsung 26" 720p panel use AMLCD 26" option.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      How do i access the service menu tom. I remember doing it before with the remote. Think its info. Enter. Menu. Power ? Is that correct
        From standby Info Menu Mute Power for a European Samsung.
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          got it Tom thanks, change screen size to 26" and also change the option to AMLCD26"
            09-07-2024, 05:50 AM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
          • alro7779
            Samsung UN55MU6103F video problem; has colored stripes on the display
            by alro7779
            Hello, everyone!
            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
            09-27-2025, 11:29 PM
            09-06-2024, 11:40 PM
