Lg oled tv oled77g7t no picture
  • Roncruz
    Roncruz
    • Jan 2022
    • 18
    I got an oled tv bought from a surplus shop it never had an issue before. the previous owner used it for atleast 3 hours of watching it never did showed a problem at screen, the picture is clear, no dead pixels and there is no shadow at all. on the other hand after a couple of hours of watching the tv went blank it as stated from the owner it just went out no response nothing. The tv got sold for as is and that is the time i got it and after bringing it home i just tried to plugged it in the screen showed a very thin line i can hear the click right after it powered up after that nothing else the optical port is lit what should i do in this case. Sometime its very thin line and it will just showed for atleast 2 secs and gone itried couple of times nothing happened.
  • Roncruz
    Roncruz
    • Jan 2022
    • 18
    The photo above that is the line showed in the screen
    • Sam Scarbo
      • Oct 2023
      • 38
      As a first step check, i would suggest to open the case, re-seat all the flat cables, and look for any exploded caps or burnt components. Try to avoid messing with the fragile flat panel too much to avoid damaging something else there.
      Good luck!
      • Diah
        • Feb 2013
        • 6545
        as you have optical port is lit on. mean no SOS signal of panel fault ... for me it sound you have Problem at the Power boards EVDD rail.. or the Fuse of this EVDD rail at the T-CON broken so check this 2 points..
        • Roncruz
          Roncruz
          • Jan 2022
          • 18
          Thankyou! Iwill post an update here later.
          diah sam scarbo
          • Roncruz
            Roncruz
            • Jan 2022
            • 18
            I had checked the fuses and the voltage coming put from the tcon i do have 12v and 24 volts but this time tv is shutting off after 10 secs of running still dont have display
            • Diah
              • Feb 2013
              • 6545
              unplug only the evdd 24V socket from the T-CON side , and turn on see if the optical remain on
              • Roncruz
                Roncruz
                • Jan 2022
                • 18
                Iunplugged the evdd socket at tcon side and turn it on optical port is lit
                • Diah
                  • Feb 2013
                  • 6545
                  can you hear sound if you plug it in ARC HDMI Signal !
                  • Roncruz
                    Roncruz
                    • Jan 2022
                    • 18
                    There is no sound only i hear is the relay clicks
                    • Diah
                      • Feb 2013
                      • 6545
                      how it come ? yours LG response to remote or... so you can put it in standby and turn it on too at time the evdd socket unplugged from t-con.... please confirm
                      • Roncruz
                        Roncruz
                        • Jan 2022
                        • 18
                        Yes i can turn it on via remote control with evdd unplugged. 3 blinks then 3 seconds shuts off. Then turn it back on same process, even the evdd socket connected. That is only the cycle that is why i can report the optical is lit. Im guessing it went to protect mode.
                        • Roncruz
                          Roncruz
                          • Jan 2022
                          • 18
                          • Diah
                            • Feb 2013
                            • 6545
                            by LG no counts of LEDs at any test .. our sign optical lit on and remain on. forever Tv are On
                            • Roncruz
                              Roncruz
                              • Jan 2022
                              • 18
                              I understand. In my case my tv shutting off and relay clicks at the second time.
                              • Diah
                                • Feb 2013
                                • 6545
                                the second relay Clicks are SOS Signal some where issued , need to know from where the issue come.
                                try first the lower LVDS cable only between MB and T-CON unplugged it ( the lower only not the top one.. other sockets should be in place ) turn on and check the optical if always on
                                • Roncruz
                                  Roncruz
                                  • Jan 2022
                                  • 18
                                  Tried plugging in with out the second lower LVDS connected. It turns on with the same 2nd clicks and the optical is not always on.
                                  • Diah
                                    • Feb 2013
                                    • 6545
                                    in this case... need to take out the PSU on the table to test it standalone to see if it turn on and produce all need voltage..
                                    if it does. then try unplug wifi / BT speaker to reduce load on MB. if the issue remain need to inspect the MB
                                    edit: you need to have service remote to send power_only and in_stop in case there are issue at MB, some time MICOM SW play in wrong way
                                    • Roncruz
                                      Roncruz
                                      • Jan 2022
                                      • 18
                                      Okay thanks will check
                                      • Roncruz
                                        Roncruz
                                        • Jan 2022
                                        • 18
                                        I tried removing and unplugging the speakers and wifi still wont same issue, psu voltage is good and complete tried power only and send in stop nothing happened. I looked out after the mboard i saw underneath is quite black like its burnt? Ill send a photo
                                        • Rauni
                                          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                          by Rauni
                                          Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                          Read also that we should test what happens if we...
                                          10-01-2023, 12:06 AM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
