Samsung LA46S81B LCD Problem
  • KCLim168
    • Sep 2018
    • 5
    • Malaysia
    I have this issue with my LCD TV. The bottom part of the screen colour is a bit off from the rest. And the refresh on that part seems to be slower and thus I get ghosty image. (kindly refer to the attached photo)
    Is this likely to be an easily fixable problem?
    Appreciate guidance from whomever knows the likely cause of this problem.
    Thank you very much
  • nomoresonys
    • 12276
    • U.S.
    Reminds me of the old problem of the tab bond connections not getting good contact any more, sometimes can be "fixed" with a shim or maybe tape. Some videos on youtube with this type of "fix".
    • nomoresonys
      • 12276
      • U.S.
      Here's an example, notice how a little pressure clears up the picture, if that does not clear up the picture then the tab bonds are probably ok, you could start by making sure the flat cables from tcon to panel driver boards are clean and not damaged, can clean with isopropyl alcohol, some use a pencil eraser, not to hard they can be delicate: https://www.youtube.com/watch?v=vCExlSnG4yY
      • KCLim168
        • Sep 2018
        • 5
        • Malaysia
        Thanks for your suggestion. Will try to get some help from my local DIY community.
          09-07-2024, 05:50 AM
        • howardc64
          Samsung UN55JU650DF network/streaming problem
          by howardc64
          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
          07-09-2025, 12:44 PM
        • alro7779
          Samsung UN55MU6103F video problem; has colored stripes on the display
          by alro7779
          Hello, everyone!
          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
          09-27-2025, 11:29 PM
          09-06-2024, 11:40 PM
