L.G. MZ-42PZ14, anyone know anything about these ancient Plasma sets?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    I have one waiting for me at work, had a very quick look over it Friday, didn't even power it up, as it was a bit damp having sat outside in a skip overnight, looks complete and in reasonable/unmolested condition, and pretty clean/dust-free inside....
    A little research suggests this monitor-only 480i set is one of the first Plasma sets commonly available at a Huge cost of £2,500 in 2001/2.....!
    I thought of bringing it home as a curiosity!
    TELEFIX
    Re: L.G. MZ-42PZ14, anyone know anything about these ancient Plasma sets?
    What's the panel in it?
    LG have a few generations of panel:
    PDP42SD1 = never released except in Korea, 1st gen IPM/discrete panel, SD, 2001, extremely rare
    PDP42SD2 = 2nd gen IPM panel
    PDP42SD3 = first started appearing in retail shops etc.
    PDP42SD4 = ...
    PDP42V5 = 5th gen IPM panel, 1st of the "V" series, reasonably popular
    PDP50X1 = 1st gen 720p panel, 50 inch first, 2005 (X=XGA res, V=W-VGA res)
    PDP42X1 = 1st gen 720p panel, 42 inch, 2005/2006
    PDP42V6 = ...
    PDP71H1 = first(?) 1080p large plasma, beating Panasonic by a year
    PDP42X2/A = 2nd gen 720p panel, 2006/2007
    PDP42V7 = ...
    PDP42V8 = last of the SD/VGA panels but made up until about 2010 for developing markets
    PDP42X3 = 3rd gen 720p panel, 2008
    PDP42X4/A = 4th gen 720p panel, 2008/2009
    PDP42G1 = 5th gen 720p panel, dropped IPMs (too many issues on X2/X3)
    PDP42G2 = 6th gen 720p panel, LESS sparklies issues but has some minor
    PDP50H1 = first 1080p small panel, 2008
    PDP50H2 = generic 1080p small panel, 2009
    PDP50H3 = high grade 1080p small panel, 2010
    PDP50R1 = generic 1080p panel, 2010
    PDP50R2 = same as PDP50R1 plus a few changes, late 2010
    PDP50R3 = generic 1080p panel, 2011
    PDP50R4 = generic 1080p panel, 2012~2014
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Wow! You really Are a wealth of information!
      Not sure of the chassis in it, didn't take note of that--will let you know....
      TELEFIX
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Its a PDP42SD3.
        I got round to it this afternoon and fired it up.
        It actually works too! didnt have to do anything to it, just checked this and that before applying power,--not a sign of any sparklies and a good picture--which was from a PC.
        --Only prob with the set is its lack of any tuner or conventional video source inputs. Its designed for use with its own set-top-box,--which I dont have, or from a PC....
        Just How this set has survived the last week or two has amazed me. First, it would have been put into a skip, then had other sets piled all around/on/over it, hauled onto the back of a wagon, rumbled round the streets of Swansea, and then dumped out all over the concrete floor by tipping the skip up while on the back of the truck, with all the other sets, mostly old CRT ones--probably in the rain!
        It was then put into a steel skip ready to ship to the TV recycling-co. I spotted it on one of my usual rounds looking for spares, and saved it along with a Samsung and another two LG plasmas. These were then loaded into a large plastic skip and transported with a forklift from the other side of the site to my W/S.
        Somehow--It survived.....
        Think after all That, It deserves a good home, I'll bring it home tomorrow....
        TELEFIX
        • SurrealMustard
          What parts can be salvaged from a plasma with a damaged display panel?
          by SurrealMustard
          I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
          03-09-2025, 08:29 PM
        • howardc64
          LG 49UJ6500 LCD panel lighter band that goes away
          by howardc64
          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
          02-19-2023, 12:13 AM
        • triplefour
          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
          by triplefour
          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
          tcon is built into mainboard.
          Only one cable goes to panel boards.
          there is a cable from one panel board to the other that links them.
          cost cutting measure that results in us having harder time to diagnose.
          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
          07-28-2022, 07:59 PM
        • Storyteller12
          QN55Q60R Service Menu Panel Help
          by Storyteller12
          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
          01-13-2024, 01:57 PM
        • maneatingmonkey
          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
          by maneatingmonkey
          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
          03-27-2024, 07:17 AM
