Lg 42pj350
  • sekino
    • Aug 2012
    • 25
    • Slovakia
    Lg 42pj350
    hello again, my tv is not working properly anymore. I changed bad YSUS board, tv works for 3 days normaly, then it sudenly shows white stripe on the bottom of the screen, first bigger one then smaller, shows OSD for few seconds and restarts. See video https://app.box.com/s/p99duuc60f5m8gv36nw9 (sorry for bad quality). Any help?
  • tw2005
    • Oct 2011
    • 6458
    Re: Lg 42pj350
    looks like bad bottom buffer but check ysus to buffer connections.
    Also check buffer for shorts and all screws are in on the ysus and tight.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • legg
      LG 42PC3 buffer output doesn't follow YSUS
      by legg
      LG42PC3D -UD originally with green lamp but no display or audio.
      Owner says was working, then went 'pop'.
      All 5V caps bulging. replaced.
      All PSU output voltages within spec but -Vy is low on YSUS.
      One of three parallel fets between SUS_OUT and SUS_DN is zenering,
      eventually shorts DG. Replaced all 3 - -Vy now OK.
      Y scan buffer test point does not follow YSUS output below -50V
      Note: This unit seems to expect YSUS output to park at -Vy in between
      drive signal pattern periods. A replacement drive signal board confirms this....
      11-18-2021, 11:49 AM
    • Yanleb
      Schematic or datasheet for Plasma TV buffer chip
      by Yanleb
      I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
      So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
      Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
      05-18-2022, 01:36 PM
    • Rauni
      Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
      by Rauni
      Hello, this is my first post on this forum, and my first attempted to repair a TV.
      My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
      Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
      Read also that we should test what happens if we...
      10-01-2023, 12:06 AM
