samsung ps-42q96hd problem
  • wishmasteruk
    • Feb 2014
    • 6
    • East Yorkshire
    hello every one
    i have a problem with this tv, it had the clicking problem that these tvs get but i think the problem was left too long before getting fixed, iv replaced the bad caps on the power board and it seems to be getting right voltages at all points , clicking has stopped but when powered up i get this picture, anyone got any ideas?
    Re: samsung ps-42q96hd problem
    Is that all you get on the screen? Tried the test pattern jumper?
    https://www.badcaps.net/forum/showpo...61&postcount=2
    • wishmasteruk
      • Feb 2014
      • 6
      • East Yorkshire
      yeah thats it, no i have not but it looks like this is my next test thank you
      • tw2005
        • Oct 2011
        • 6458
        May have corrupted an EEPROM. I know on some of the LCD models there was a side effect of PSU caps going causing endless cycles and after correcting the PSU the EEPROM was corrupt.
        I'm thinking mainboard, so hopefully the test pattern jump Tom mentioned will come up good.
        • Dang
          • Aug 2013
          • 440
          Try reseating every connector making sure there fully back in, it's possible that you may have knocked or not put back properly one of the connectors after the caps change.
            09-07-2024, 05:50 AM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
          • alro7779
            Samsung UN55MU6103F video problem; has colored stripes on the display
            by alro7779
            Hello, everyone!
            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
            09-27-2025, 11:29 PM
            09-06-2024, 11:40 PM
