HI to all, I got this tv, with the original problem of no power on, I replaced the power supply and now it is turning on for few sec then turn back off and the standby light is flashing 9 times, I can see in the screen when I turn it on the the left side has backlight for few seconds but no the right side, I think is related to the d2 board but im not sure. also can somebody has the schematic to troubleshoot the d2. thanks!
Sony KDL-46XBR2
by NSkyLabI though I've seen all possible kinds of failures but this one is new...
Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?... -
by Watson306Hi,
I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
Many Thanks in advance. -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
by ptcriserx3Hi
Ive got a vintage 2001 sony trinitron flat tube tv
The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
See many images attached...
Just windering if this is not fixable or something i can correct without getting too invloved
Im trying to sell the tv
Thanks -
by flibidyI have here a Magnum IA.100 which belongs to my parents.
The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
What Ive done........8 Photos-
01-01-2025, 01:26 PM -
- Loading...
