42PA30RQ Troubleshooting Dim Raster and Image
  • corkyapv
    • Feb 2014
    • 12
    • Puerto Rico
    VSus, VA good. Logic Board, Y, X and buffers. Unit turns on with no problem sound working, logic board led blinks once every second. Not sure if panel is defective.
    Have read through the forum still unable to find corrective action. Thanks in advanced to all.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: 42PA30RQ Troubleshooting Dim Raster and Image
    Dim picture generally X_SUS faults.....
    Check the waveform at the TP or the panel connector....
    TELEFIX
    • corkyapv
      • Feb 2014
      • 12
      • Puerto Rico
      I have replaced X board sorry for not mentioning.
        Can we see a picture? Not all X-main you buy from eBay are tested and working...
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Have you tried running the test-pattern functions direct from the Control-Board?
          TELEFIX
          • corkyapv
            • Feb 2014
            • 12
            • Puerto Rico
            Thanks for the pdf. I have attached a photo display.
            • corkyapv
              • Feb 2014
              • 12
              • Puerto Rico
              I have ran the test pattern they are seen on the background very dim. Also checked LVDS cable for continuity.
              • lookimback
                • Aug 2013
                • 1489
                In my opinion, parts for this particular TV should only be purchased from Shopjimmy or another reputable supplier. I say this because the majority of parts sold on Ebay really are not tested, and, in this particular model there is a high probability of a defective board damaging other boards.
                Also, I checked Shopjimmy yesterday while working on same model and parts are same price or cheaper than current Ebay listings.
                ------------signature starts here------------
                • corkyapv
                  • Feb 2014
                  • 12
                  • Puerto Rico
                  You are right I did get the boards from ebay. Now that was my mistake. I did check the boards for shorts and buffers as per video. Dont have schematic for the X board, are there any voltage checks and can make to verify output?
                  • corkyapv
                    • Feb 2014
                    • 12
                    • Puerto Rico
                    I have no problem ordering the board again. Is just I have invested time and a lot of effort on this unit. Would hate to have it scrap
                      Its definitely an X-main problem looking at that if that helps.
                      • corkyapv
                        • Feb 2014
                        • 12
                        • Puerto Rico
                        I will order another X board and post results. It should take about 10 days. Any chances of short on the display. Thanks Tom
                        • corkyapv
                          • Feb 2014
                          • 12
                          • Puerto Rico
                          Tom I found this after removing front cover, is this repairable? I see small sparks when tv is initialized. Thanks...
                            Where are the sparks occurring? Possible to get a video?
                            • corkyapv
                              • Feb 2014
                              • 12
                              • Puerto Rico
                              It happens at this connection looks like corrosion, humidity. Initial spark only on this top connector which powera from main x board. All others look clean .
                                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 02:20 PM
                              • Jaime Morillo
                                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                by Jaime Morillo
                                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                The TV was stuck on the logo and I couldn't access the update menu.
                                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                The image result was good, but the image is inverted.
                                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                08-18-2025, 11:38 AM
                                HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                09-06-2024, 10:56 AM
                                HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
