Vestel tv, how to flip the image?
  • yokoono
    replied
    Post here so we can see what file you have.
  • Aladel
    replied
    Thanks a lot for your reply,
    I am sure the code 4725 is now giving you the diagnostic mode not the service mode,
    I am using a Samsung panel instead of the orginal one, the panel model number is
    LSC320AN10-a02
    I can take of the bios of it and read it, but what modifications i need to do with the file to fix my issue
  • yokoono
    replied
    1. At Vestel, you enter SM with MENU 4725
    2. I haven't had any TVs with 17MB481 repaired
    3. I haven't found the option to rotate the image in SM
    4. To do this, you need the panel profile. I don't know if the panel profile can be saved on the 17MB481.
  • Aladel
    replied
    Hi, I am looking for the service menu for vestel tv, but the code usually used 4725 is not working anymore, it show diagnostic menu and no usb or any other options,
    I tried many codes with no luck.
    I have toshiba 17MB481 and I am the pic is upside-down because of changing the panel
  • fatflow
    replied
    Hi
    I made a small tool to change the panel settings for 17MB211 mainboards.
    You can mirror the image and invert the bits/colors with it. If anyone wants to try it's available in my GitHub.
    https://github.com/notiren/17mb211_flasher
  • yokoono
    replied
    Good. ✌
  • fdurzu@gmail.com
    replied
    It works! Thank you so much for your support yokoono 😀
  • yokoono
    replied
    I turned the image into the panel profile you posted.
  • fdurzu@gmail.com
    replied
    It’s 17MB181TC, there’s a typo in the file name, sorry!
  • yokoono
    replied
    17MB110 or 17MB181TC ??.
    1. Format a stick with FAT32
    2. Create a folder called pq on the stick
    3. Unzip and put the 2 files in the folder
    4. Turn on the TV, USB stick and type MENU 4725
    5. Go to USB Operations and type OK on the remote control
    6. Wait 10 seconds and exit the menu (return, back)
    7. Turn off the TV from the remote control
    8. Wait until the stby LED on the TV stops flashing
    9. Unplug the TV and wait until the stby light goes out.
    10. Take out the stick and turn on the TV.
    If the image is not correct, repeat the operation
  • fdurzu@gmail.com
    replied
    Hello, same issue here (flipped image): Telefunken TV mod. TE32550B42V2DW, board 17MB181TC, panel VES315WNQX - L3 - N01.
    Thank you!
  • yokoono
    replied
    Originally posted by Gyannini
    Worked perfectly!
    Thanks so much for all your (and lightning) help!
    Kind regards,
    It could have been faster.​😁😁
  • Gyannini
    replied
    Worked perfectly!
    Kind regards,
  • yokoono
    replied
    Thanks so much Yokoono, it worked perfectly!!!
    I'll now start to investigate my 2nd challenge, to fix the colours
    Kind regards from Portugal
    Try
  • Gyannini
    replied
  • yokoono
    replied
    Hi, good afternoon!
    Same problem here. I've installed a vestel 17mb211 on my TV and the image is flipped upside down.
    I've tried to follow your instructions for folder downloadpq.mb211 and I've got the attached files.
    Are you able to help one more time, yokoono? Thanks in advance for any help!
    Look.
  • Gyannini
    replied
    Hi, good afternoon!
    I've tried to follow your instructions for folder downloadpq.mb211​ and I've got the attached files.
  • yokoono
    replied
    Originally posted by Buddens
    Operating windows 11 and dont have option for FAT32...is there any other option for formatting?
    Ask a friend for help.
  • Buddens
    replied
  • yokoono
    replied
    its a panel board from a luxor vestal tv to a toshiba tv
    image is upside down. the main board is called 17mb211s
    Save the panel profile from the TV and post it here to return the image.
    2. Create a folder called downloadpq.mb211 on the stick
    3. Turn on the TV and type MENU 4725
    4. Go to USB Options and type OK on the remote control
    5. After 10 seconds you can remove the USB stick and you will have some files on the stick.
    6. You post them here.
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
    MSI Summit E13 Flip Evo E13 FLIP EVO A11MT-018AU Hybrid (2-in-1) Specification for Upgrade or Repair
    This specification for the MSI Summit E13 Flip Evo E13 FLIP EVO A11MT-018AU Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E13 FLIP EVO A11MT-018AU boardview and E13 FLIP EVO A11MT-018AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-07-2024, 04:10 AM
    MSI Summit E16 FLIP EVO A13MT-262BE Notebook E16 Flip Evo Specification for Upgrade or Repair
    This specification for the MSI Summit E16 FLIP EVO A13MT-262BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E16 FLIP EVO A13MT-262BE boardview and E16 FLIP EVO A13MT-262BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 06:38 AM
    MSI Summit E16 FLIP A13VET-027BE Hybrid (2-in-1) E16 Flip Specification for Upgrade or Repair
    This specification for the MSI Summit E16 FLIP A13VET-027BE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E16 FLIP A13VET-027BE boardview and E16 FLIP A13VET-027BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    MSI Summit E16 FLIP A13VFT-020BE Hybrid (2-in-1) E16 Flip Specification for Upgrade or Repair
    This specification for the MSI Summit E16 FLIP A13VFT-020BE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E16 FLIP A13VFT-020BE boardview and E16 FLIP A13VFT-020BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
