Toshiba 32AV502RZ LCD flickering/double image
  • Dogbutch
    • Feb 2014
    • 8
    I am playing with a Toshiba 32AV502RZ that has a flickering LCD. all inputs including menu. kind of a double image look to it.
    the previous owner ripped the coaxial input off of the main board. There does not seem to be any physical dammage to the board and I have removed the RF input case from the main board. I plan on using HDMI input anyway
    as I am typing this. it stopped doing the flicker...
    here's a video. http://youtu.be/nNSug8g5Q2s
    I will follow up with more info
    Phil
    Re: Toshiba 32AV502RZ LCD flickering/double image
    Bad panel - tab bonds. May or may not be fixable.
    • Dogbutch
      • Feb 2014
      • 8
      powered off and on and problem came back.
      • Dogbutch
        • Feb 2014
        • 8
        left on for 4 hours and it stopped the double image
        • Dogbutch
          • Feb 2014
          • 8
          tv ran fine for 6 hours +
          powered off for an hour and double image flicker came back.
          • Dogbutch
            • Feb 2014
            • 8
            also noticed that the vertical spacing of the double image gets less and less as the TV warms up. after an hour there is no spacing left and tv runs normal.
            are we still thinking bad LCD panel??
            • Dogbutch
              • Feb 2014
              • 8
              running now for 24 hours. no issues. but if I power off I will get double image for the first hour or so..
              what could be the issue?
              thank you
              • johnboy1313
                • Nov 2012
                • 1959
                thank you
                You've already got your answer above
                • Dogbutch
                  • Feb 2014
                  • 8
                  thank you
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Tab-Bonding is a problem on many sets....
                    The thin Kapton film connections from the glass of the panel to the PCB along the top of the panel come adrift.
                    Sometimes a temporary repair can be made by using double-sided foam-tape between the frame and the Kapton film where it attaches the glass and where it attaches the PCB.
                    --Its not a proper repair, more a 'botch' but better than nothing, and all that can be done.
                    There's no other way of fixing these issues.
                    TELEFIX
                    • howardc64
                      TCL 49S405 double image
                      by howardc64
                      LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                      This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                      06-23-2025, 03:20 PM
                      09-06-2024, 05:27 AM
                    • Cornito
                      Samsung UE55RU8000 reboot and then double image after heating up
                      by Cornito
                      Hello team,
                      I'm back with another tv and another problem.
                      I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                      First, reboot issue, I use tape Method to find out the right side that cases the issue.
                      Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                      Then double image reduce in height and move to the top.
                      The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                      When I...
                      03-31-2024, 01:37 PM
                    • piershs
                      Toshiba plasma 50WP16 wierd double image fault
                      by piershs
                      My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                      Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                      • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                      • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                      08-01-2020, 01:07 PM
                      09-06-2024, 05:59 AM
