Samsung/UN65H6300AF LOGO APPEARS AND SHUTS OFF
  • Super360
    replied
    Ok just as a long past due update. I replaced motherboard, PSU as it was making a humming noise and the entire led strip. Basically completely rebuilt this tv. Definitely not worth it but it was fun anyways.
  • Davi.p
    replied
    I said remove all lenses..
  • Super360
    replied
    Originally posted by Davi.p
    I warn you that the led lenses must be removed almost all, otherwise in short time them will fall, you can leave some on if them resist to a strong pulling.. this is a disaster tv!
    so haven't you used hot air?
    Wait so are you saying I should just replace the entire led strip? And no I didn't need to use hot air nor do I have hot air station, I just flooded the chip on both sides with solder and flux and got them both hot and moved it off when solder was molten.
  • Davi.p
    replied
  • Super360
    replied
    How do you removed the memory?
    It was the eeprom chip not the memory chips and it was easy just put some flux on the chip flood it with lead solder (both sides) and heat both sides up and slide the chip off, Then use de soldering braid to make the pads flat and put new chip in no big deal.
  • Super360
    replied
    Well just a little update I put the replacement motherboard I bought offf e-bay in and it's working great now. It no longer shuts off every 3 mins like it did when I replaced the eeprom memory chip. So I would call this fixed. Now all I have to do is replace the psu as it makes a horrible buzzing sound that makes watching tv unbearable. And the one other issue is some of the led diffusers fell off so they will have to be re-glued but no big deal. Main problem fixed. thanks everyone.
  • Davi.p
    replied
  • Davi.p
    replied
    My suggestion is that the best thing to do is to bring the board to a profess. lab. for reballing each one bga, costs permitting, receive it, test it for at least 3 days, then seal around each bga on board with hot glue and close the tv, the replacement board will have same problems past a certain time..
  • Super360
    replied
    I'm not gonna believe it.. i'm sorry..
    Well I spoke a little to soon as it did power on and somewhat function but it kept turning off and freezing. It will display a image at least but like I said after 3 mins restart itself for no apparent reason. So it looks like a motherboard replacement is the only thing that will fix this tv at this point.
  • Davi.p
    replied
    I’m not gonna believe it.. i'm sorry..
  • Super360
    replied
    Originally posted by Bholu
    My friend, there is a 8 pin eprome ic attached to this board.rilace it with the new one same nomber remember you do not need to program new ic place the ic as it is. Thx
    Well bholu was absolutely correct. I literally thought this wouldn't work but I bought a Winbond W25Q40CLSIP erased eeprom with no programming what so ever. I just got it today and soldered it in and really had low hopes of it fixing my issue. I soldered it in anyways thinking I have nothing to lose. Well when I turned the tv on after installing new eeprom it did the same thing smart logo then blank... turned it off and turned it back on and wouldn't you know it that it came alive right before my very eyes. What a great surprise. Thanks to all you guys for your help.
    Edit: and yes I'm going to clean up that rosin flux all over the board lol.
  • Super360
    replied
    Originally posted by Diah
    of course it had since its Linux, there are user mode at bootloader section called mmc.restore.communicated with kernel permission.
    @Super360
    Spi sold on ebay are programmed... but some used one size dump for example 50 and sell it for all size.
    however since yours 65 , it will worth to look at the panel edge boards... you may will find on left and right side U ribbon connect 2 half side.... if this the case disconnect on atime and turn on.. just to be more sure.
    appreciate all you guys for all your help. I am continuing forward with buying a replacement board off ebay and will update you on the results.
  • Diah
    replied
    Originally posted by lotas
    This won't work with Samsung, it doesn't have a recovery mode, firmware restoration, if you have the cheapest CH341A programmer, then you can try to reprogram the spi flash 25q40cl chip, if it doesn't help, then sell it, since the node will already program the eMMC, then here you will need an expensive programmer to work with eMMC and knowledge... I will provide you with the firmware for 25q40.
    @Super360
  • Davi.p
    replied
    A question to the professional tinkerers that usually repair bad emmc software with the in line / icsp programming, does this job lasts many months / years usually ?
  • lotas
    replied
    The problem here is not the bga soldering, the problem here is a malfunction of the spi, eMMC ("H" series) firmware.
  • Super360
    replied
    Are you able to do reballing? A first step could be a slight heating of all bga, this can in a lucky sit. activate a bit the bad balls, just to diagnose it well, then the second step if no go is a full reflow with a lot of flux, when confirmed bad balls do a reballing, anyway reballing of all the set of bga is the best, if a light reflow or complete freezing in a fridge gives no complete boot then the emmc partitions has some flaws, you can diagnose it by uart pc connection, when you see error in file reading + unable to mount partition (users partition usually) then file structure is gone and this probably due to bad balls as well..
    Adding a mention.. a small amonut of percentage is still the bad panel, there possibly be a small bastard going s.c. under a certain period when image is sent, so try unhooking the lvds ribbon and hipe to get audio from the soeakers.. it seems tcon integrated to MB so no screen test can be made.. (f***k Samsung..)
    Yea I can actually solder quite well but reflow/reball is defiantly out of my skill set. I did unplug the lvds cable that plugs in the motherboard and there is no sound what so ever.
  • Davi.p
    replied
    Are you able to do reballing? A first step could be a slight heating of all bga, this can in a lucky sit. activate a bit the bad balls, just to diagnose it well, then the second step if no go is a full reflow with a lot of flux, when confirmed bad balls do a reballing, anyway reballing of all the set of bga is the best, if a light reflow or complete freezing in a fridge gives no complete boot then the emmc partitions has some flaws, you can diagnose it by uart pc connection, when you see error in file reading + unable to mount partition (users partition usually) then file structure is gone and this probably due to bad balls as well.. i mean, data can be ok but balls looses contact with heat and gives error, or data is bad due to contact being bad during a past usage of tv, especially in write operations (installing apps, changing settings..)
    Adding a mention.. a small amonut of percentage is still the bad panel, there possibly be a small bastard going s.c. under a certain period when image is sent, so try unhooking the lvds ribbon and hope to get audio from the speakers.. it seems tcon integrated to MB so no screen test can be made.. (f***k Samsung..)
  • Super360
    replied
    This won’t work with Samsung, it doesn’t have a recovery mode, firmware restoration, if you have the cheapest CH341A programmer, then you can try to reprogram the spi flash 25q40cl chip, if it doesn’t help, then sell it, since the node will already program the eMMC, then here you will need an expensive programmer to work with eMMC and knowledge... I will provide you with the firmware for 25q40.
    yea, I have a replacement 25q40 coming in the mail. The one guy said that it doesn't even need to be programmed which I find hard to believe. But yes I would much appreciate the firmware for that chip and I'm going to pick up this programmer.
  • lotas
    replied
    Originally posted by Super360
    Ok tried all your steps other than I can't find a usb drive smaller than 4gb but the led didn't even flash for the usb drive once. I formatted it as fat and mbr and made sure to change how I put the file on the drive like you mentioned. I think I'm going to just put a replacement board in this tv and sell it on. Will keep everyone updated.
  • Super360
    replied
    we are here in this forum related to our way to solve problem.. we didn't copy result from other forum or users... we know its hard but we will not say impossible... the impossible when firmware vanished from eMMC... there will be other miracle it t bring it back... try and try later if this or any other method suggested over this forum will be answer over all YouTube or forums.,
    when i wrote MBR mode and FAT or EXT its way to trick the SPI to handle the stick as part of HW... this TV linux.. and who know or worked with Linux FW & HW and compile stuff will never say there are no way
    one things more i gave link for factory firmware 0000 which its only allowed you to downgrade.to 0000 then you are free what you will do withe set
    09-07-2024, 05:50 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
    Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
    This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 06:20 PM
