Zenith Z42PX2D - plasma - audio, no video
  • whitejohnny71
    • Mar 2010
    • 26
    Hi Folks, looking at a Zenith 42" model Z42PX2D. The unit powers on with a black\blank screen. Tiny little sparkles of red and green can be seen randomly around the screen. I hear open channel static and the volume controls work. The channel button cause the audio to mute for a moment so it appears to be working. (I don't have cable tv or a signal source at the moment so I haven't tried to verify that further). So it seems the power supply and the mainboard are ok.
    I measured all regular and smd fuses visible and all are good. All power supply output voltages measured correctly.
    I have some tools - hot-air rework tool and soldering iron, 20meg scope and voltmeter. I routinely repair laptop motherboards with and without schematics as well as lcd monitors and other consumer electronics (car stereo amps, etc) so I'm not clueless, but I just don't do enough plasmas to know what I'm looking for.
    So all help appreciated! Where do I start?
    I have attached pics of the boards and the overall set...
  • whitejohnny71
    • Mar 2010
    • 26
    more info
    Also, on the left side, the 3 metal plate power connectors between the y-sus and buffers measured -32, +17 and -32 to ground. I've circled them in the attached pic.
    • whitejohnny71
      • Mar 2010
      • 26
      Re: Zenith Z42PX2D - plasma - audio, no video
      I have the service manual. Is it possible for this symptom to occur if the voltages are out of alignment?
      Hmm, ok, aligned at Va=65 and Vs=184, off then on, no change. Hit power button, green led blinks 5 times, 3 seconds later, hear audio static but no picture.
      • whitejohnny71
        • Mar 2010
        • 26
        From what I've read, can I pull the lvds feed to see static like with an LCD or should I net do that? Def not trying to make anything worse.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Set off--pull the LVDS cable from Control-board, locate the test-points (depends on whether LG or Sams. panel,where and how, Looks like a 42V6 LG to me) and short the two.
          Power-up, panel should display various test-patterns on a continuous loop.
          If not, you have either a control, X-sus, Y-sus or PSU fault.
          --Looking at that set, it has IPM's These are the most likely cause of problems. Scope-tests will indicate which is faulty, as well as the condition of the Vs fuses....
          TELEFIX
          • whitejohnny71
            • Mar 2010
            • 26
            Test points - LG panel
            Hi, thanks for your help Alastair. Yesterday after reading about the test points in another Zenith thread, I checked but couldn't find anything in the service manual.
            The panel is an LG PDP42V7. I had to remove it from the table for lunch (my office workbenches are full at the moment) but I will check the last digits later. I've attached a pic of the stickers.
            Any idea where the test points are?
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Oops--Sorry, Its a 42V7.
              Same advice applies though....
              TELEFIX
              • whitejohnny71
                • Mar 2010
                • 26
                I'll prob not be back to it for a day or so (i normally do laptops and desktops; gotta keep the flow going) but if anyone is familiar with this model or the 42v6 if you could let me know where the test points should be I'll try that as soon as I can get to it. Its my understanding anything between 100 and 470 ohms between the points is ok right?
                • samson7point1@yahoo.com
                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                  by samson7point1@yahoo.com
                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                  The player processes the audio signal using two different reference frequencies. The "R"...
                  04-30-2024, 11:22 AM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • chazh
                  LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                  by chazh
                  This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                  I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                  The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                  09-01-2025, 08:56 PM
                • ItepK
                  Panasonic TX-P42G30E green light blinking, no video, no audio
                  by ItepK
                  Hey everyone!
                  I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                  This post describes my entire troubleshooting process of this TV.
                  When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                  I've taken the unit apart, and I've started to check some voltages:
                  • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                  12-22-2023, 05:06 AM
                  HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
                  This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
                  09-12-2024, 03:36 PM
