SAMSUNG LE32C450 not booting
    I have a samsung LE32C450 which is not booting
    I fixed all or part of the PSU by replacing the FAN7530 and the hybrid IC, and everything seems OK as all the voltages are OK, backlight is working and the TV sets itself ON when using the remote
    After being set out of standby, the TV doesn't boot as there is no menu or sound
    The red LED blinks to the remote commands though, after the LED has blinked 5 times
    Resetting the EEPROM did nothing
    I read it might be a TL431 which would be bad but the PSU seems fine now...
    Would anyone be able to help me?
    Re: SAMSUNG LE32C450 not booting
    Do you have good 12V at both ends of the fuse on the t-con board?
    Don't rely on the melody start up sound. It is an option that the user can turn off in the setup menu. Also, selecting a source with no image can be difficult.
      The T-CON fuse is not open, I checked it
      I may have to re check for the 12V at the T-CON ribbon, but I recall having measured some 5V and 3V3 paths at the ribbon test points underneath the board
      Are there known scenarios anyone could describe me so I'd be able to work more than 5 minutes before having to ask again?
      I'm into TV repair since that one, so I still have to learn a bit, even if I have repaired much things for years... so I have to learn a bit
        To confirm T-con function, check AVDD, VGL (or VOFFE), VGH (or VONE) on t-con board.
          Would it be the same signals as at the other side of the ribbon? I'd like to avoid dismantling the T-CON and creating bonding faults at the LCD
          If I can measure this at the mainboard side, it would be nice
          As the TV seems to get out of standby and remote commands make the LED blink, I fear the T-CON may have died for some reason... fingers crossed...
            Does this TV have a separate t-con board? Pictures please.
              hi
              the T-CON has no voltage on the VPANEL line (I guess this is the 12V line as it has 4 via and is 3mm wide)
              the main board is this one: http://www.duycom.com/wp-content/upl...N94-04175J.jpg
              the T-CON is separate... I guess I'll have to check the different regulators I can find on the board...
              I fear the main board is toasted but everything tells me there is something to find
              The TV set was working nice, then took more and more time to power itself on, up to an hour before the set was ON
              This makes me think about a bad capacitor or solder joint, or even a faulty regulator which has to heat before it works
              As I had to replace the PFC buck it may have been caused from excessive ripple... I'll have to trace the regulators, but it may be tricky on a 4 layer board like this...
                EDIT: just checked the P MOS feeding the T-CON, it tests OK and sees the 12V supply, and the command transistor of the MOS seems OK so I guess the CPU just doesn't send the command
                Does it need to boot for the remote indicator to light when commands are sent? I think not, but it is strange that the CPU seems to heat just a bit over ambiant so it's draining power... I should harness the scope but there could still be thing to try
                If you know of any scenario I could ckeck, I'd be happy
                Anyway, I'm going to visit some shops next week and maybe I'll find a spare TV of the same model if I'm not able to repair it
