SAMSUNG UE32T5372AU
  • SzymonB
    • Mar 2023
    • 15
    • Poland
    SAMSUNG UE32T5372AU
    Hello, I am asking for help. After connecting the power supply, the TV will first blink once and then after a few seconds it will blink 4 times. All voltages on the motherboard are OK, but when there is a cyclical one blink the voltages 3.3V, 0.9V, 1.5V, 12V on the L80 coil also reset. So this x1 blink is like Reset_SYS and then it's x4 blink. Where to look for the problem? There is no Service Manual, I rule out the problem of bios on IC401 because I have already done it. I found descriptions of SOS on the Internet and 4 x blink is Power SOS P Board​ Help. Regards
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4326
    • Italy - Milan
    Have to rewrite the flash memory, check http://www.badcaps.net/forum/trouble...eed-eprom-dump here for the dump
    • SzymonB
      • Mar 2023
      • 15
      • Poland
      Thanks but it's not the same problem. At the very beginning, I already reprogrammed IC401 and nothing helped
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        So the eprom near the lan connector?
        • SzymonB
          • Mar 2023
          • 15
          • Poland
          Yes IC401 i change the dump and stay that same problem red led blink 4 times
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4326
            • Italy - Milan
            Where do you get dump? Is it 100% sure?
            • SzymonB
              • Mar 2023
              • 15
              • Poland
              Yes dump it's 100% fine from badcaps. This motherboard i repair 1 year ago and then by broken this dump. Now it's other problem.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4326
                • Italy - Milan
                How many seconds before the 4 blinks?
                • SzymonB
                  • Mar 2023
                  • 15
                  • Poland
                  This is quite a difficult topic because the motherboard makes such a loop. First it blinks once, then after 20 seconds it blinks again and after 5 seconds it starts blinking 4 times. Over and over again.
                  • SzymonB
                    • Mar 2023
                    • 15
                    • Poland
                    A this moment i think is be sos code 14. Tell me that I right ?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4326
                      • Italy - Milan
                      i have blink chart for different models, not yours, has your tv got bluetooth or wifi?
                      • SzymonB
                        • Mar 2023
                        • 15
                        • Poland
                        I have wifi
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4326
                          • Italy - Milan
                          try detaching wifi module.. have you got a link for the blinking chart?
                          • SzymonB
                            • Mar 2023
                            • 15
                            • Poland
                            I disconnect wifi module and that same problem. Now i don't have link for the blinking chart. Can send me?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4326
                              • Italy - Milan
                              you told errror code 14, from where?
                              • SzymonB
                                • Mar 2023
                                • 15
                                • Poland
                                I just went a bit crazy because it blinks 4 times but it also blinks once. So my error code could be either 4 and there is one reset or code 14. Now I'm not sure myself
                                • SzymonB
                                  • Mar 2023
                                  • 15
                                  • Poland
                                  It would be best if I sent you a video of what it looks like
                                  • SzymonB
                                    • Mar 2023
                                    • 15
                                    • Poland
                                    Another question: can someone send me a dump from the IC503 24C512 memory? Because I noticed that even when I have it desoldered, the board behaves exactly the same. Maybe it's worth trying to change the eeprom input
                                    • lotas
                                      • Jan 2016
                                      • 4597
                                      • Russia
                                      Try, dump 24C512.
                                        09-07-2024, 05:50 AM
                                      • howardc64
                                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                        by howardc64
                                        • Prior owner tried a replacement main board. No difference.
                                        • Samsung 2x red blinking standby LED = panel fault
                                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                        07-19-2025, 10:54 PM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
