No Power On Lexsor 32in (LC-32w18sd)
  • ashok
    • Nov 2013
    • 7
    • England
    I have a lexsor 32 lcd. It does not power up. I checked the input AC (240v) and also checked caps etc and they all seem fine. Measured the output on the PSU and it is all zero. Checked the buck converter IC's on the second board and they not giving any output either. Any ideas/suggestions please?
  • munirutech
    • Oct 2013
    • 72
    • Ghana
    Re: No Power On Lexsor 32in (LC-32w18sd)
    hi
    when you power the tv is the stand by light on?if no then the 5v section of the psu is faulty
    • ashok
      • Nov 2013
      • 7
      • England
      no stand by light. Is that the 5v buck converter chip (on another board)? i measured the volts on that chip and there is nothing there but i thought that may be because there is no power going in from main PSU board.
      • Silver Dove
        • Nov 2013
        • INDIA
        Dear Ashok
        1. First Check the mains voltage is reaching the Power Supply Pins - Be careful while checking
        2. Check whether the SMPS transistor is working
        your SMPS seems to be dead or 5v standby section is dead
        • notallbad
          • Oct 2012
          • 1190
          Worth pointing out that the rocker switch (on/off switch) should also be checked, thats if it has one, I had a Lexsor sometime ago that had a faulty rocker switch(on/off switch).
          • ashok
            • Nov 2013
            • 7
            • England
            Thank you both
            I've checked the mains voltage on board and it seems fine and this also proves that rocker switch is functioning properly. I am thinking of removing the buck converter chip (5v 3A) and put external supply and see if it works, if it does then i will buy the chips and replace them both.
            • ashok
              • Nov 2013
              • 7
              • England
              I've found a similar PSU board on line but it is slightly different from mine. Mine is KAS200-5S241812X VER A2.1 whereas the one I've found is KAS200-5S242212X VER A2.31. I was wondering would this new PSU work and is it worth buying?
                03-31-2024, 02:12 PM
                09-06-2024, 05:59 AM
                HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 02:15 PM
              • meraklinetx
                Asus Z97-a power cycle, no boot no cpu voltage
                by meraklinetx
                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                05-10-2023, 06:08 AM
                HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                09-07-2024, 05:20 AM
