Samsung LE32S86 long time for startup
  • fabiuscom
    • Sep 2013
    • 11
    • Italy
    Hi, I got this TV seven years ago, but from 1 month, the TV need ten minutes to startup. I've opened it and I found 5 capacitors in explosion. I replaced them, but the problem persist. Yesterday I've opened Tv again and I checked with the tester points were red-rimmed, where you connect the flat of the LCD, and when I go to turn on the TV changes from 3 volts to 9 volts, then 24 volts 18 volts, until it stabilizes at 24 volts and TV turns on. What could be the problem? thanks
    Re: Samsung LE32S86 long time for startup
    What capacitors did you use as replacements? Where did you buy them?
    • fabiuscom
      • Sep 2013
      • 11
      • Italy
      I buyed it at eletronic shop, I've changed 3 of 35v 1000uf, 1 of 25v 1000uf and 1 of 10v 1000uf (replaced with 16v 1000uf)
        That is probably your issue, the average capacitors from an electronics shop are no good. It is recommended to use, for example Panasonic FC/FM/FR or Rubycon YXF capacitors. Do you have Farnell (online) available in Italy? eBay is also an alternative but you need to be careful as sometimes they are fake capacitors.
        • fabiuscom
          • Sep 2013
          • 11
          • Italy
          could you please tell me which ones to buy? Farnell shop are avaiable in Italy
            3x http://uk.farnell.com/panasonic/eeuf...35v/dp/9692312
            2x http://uk.farnell.com/panasonic/eeuf...0uf/dp/1855170
            Replace 1000uF 10V with 25V, as long as it will fit well.
            • fabiuscom
              • Sep 2013
              • 11
              • Italy
              Do you think it is better to change them all? even the smaller ones?
                May as well, given they only cost a small amount more, for longer term reliability.
                • fabiuscom
                  • Sep 2013
                  • 11
                  • Italy
                  I hope everything works again changing them
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
