Same procedure for that board but check VE instead. Panel will have VE rating written on it, expect from 80 to 150V.
And... do you have a scope? It is necessary for checking ramp waveforms...
these are the same as written in the panel except Vsc
i know you asked me 3 times Tom, and the answer is no, i dont have a scope. i can measure Hz with my multimeter but i know you are looking for the waveform. if there is conclusion without checking ramp, please tell me. i
Reason: error in measuring
Vsc should be more than -90V. That is too low IMO.
You can do some voltage checks but plasmas are hard to repair without knowing what voltages to always expect in those places, which is where a scope comes in handy.
I can't see a point for VSET, can you see one?
No Tom, i fail to see any Vset testpoint in both boards. Is this weird?
This is the service manual but there is no indication there. I extracted sth about "ramp" where your suggestion of the scope is very useful. Now (reading a bit in other threads) i am starting to understand a bit about plasmas.
Yes, the ramp is used to release the electrons from the gas making it ionised, called priming. Then sustain pulses make written pixels light up. Priming makes the screen glow slightly with no image. No priming = no glow and faint or no image.
That could possibly cause your issue. Check it with the buffer boards unplugged too.
Try adjusting Vsc/Vscan potentiometer what happens?
The Vscan moving from 170-195V...
Anyway, thank you to everyone especially Tom for helping me, but i have to give up! This tv costs me a lot of room in my working space, and also valuable time. And at this season of the year i am overloaded with work...Maybe it would have been very simple if i had the right tools and some spare parts.
Plasma tv are very challenging because of their complexity, and this determined me to have it stripped for 10 days. But i have to admit i am still not familiar with them, and still holding the negative record of fixing 0 plasmas with sustain/buffer problems (2 fixed had psu issues).
Cheers everybody and thanks again!
