Samsung DP50747 Powers on then off
  • pc_doc_al
    • Jul 2012
    • 45
    Sanyo DP50747
    Samsung Panel
    Chassis # DP50747-03
    TV was DEAD, no relays and no led, so I replaced LJ92-01510A Power Board.
    Now, Relays click and LED comes on for 20 seconds then relays click and LED goes off. Same results with Y or X sus disconnected or with both disconnected. I have no voltage on Vs, Va, or Ve. I believe my replacement board maybe bad? What is everybody's thoughts.
    Thanks,
    Steven
    Re: Samsung DP50747 Powers on then off
    Try this test:-
    https://www.badcaps.net/forum/showpo...61&postcount=2
    • pc_doc_al
      • Jul 2012
      • 45
      There is no change in results
        OK. Are there any labels next to the connectors going from the power supply board to the main board? The main board is the board with the video connectors on it.
        • pc_doc_al
          • Jul 2012
          • 45
          Yes they are labeled. I have attached a picture of the connectors.
          I just noticed that I Labeled my thread a Samsung DP50747.
          It is a Sanyo with a Samsung panel.
          Sorry about that.
          Steven
            OK, please check PS ON and AC DET while the set powers on and the relays click. All connectors/power board to be installed.
            • pc_doc_al
              • Jul 2012
              • 45
              PS ON 4.8v with power plugged in and 28.5 mV after relays click
              AC DET 5.2v with power plugged in and 5.2v after relays click.
                OK, this indicates a fault with the power board.
                Have you checked all the fuses on the power board?
                • pc_doc_al
                  • Jul 2012
                  • 45
                  Both fuses test good
                  • pc_doc_al
                    • Jul 2012
                    • 45
                    Correction, all three fuses test good
                      Any way you can see to check voltage across the 450V large caps as relay clicks in?
                      • pc_doc_al
                        • Jul 2012
                        • 45
                        The 450v caps are at 55.8V then drop to 23.6V when relays click in.
                          V DC? 55.8V is not right at all.
                          • pc_doc_al
                            • Jul 2012
                            • 45
                            Sorry I missed the "across" part.
                            386 V
                              That's OK then. The power supply is receiving the signal to turn on, but it is not starting up the main supplies. Check the Vs/Va output for shorted diodes. Also, locate any multi-pin chips near the Vs/Va output on the primary side -- if you find any list their part numbers. Any BN44, BN9x, LJ9x etc numbers on the power supply?
                              • pc_doc_al
                                • Jul 2012
                                • 45
                                Here are the numbers I found.
                                LJ92-01510A
                                LJ41-05246A
                                I see the following:
                                FDD 8880
                                LM393
                                3037cs
                                I believe all the diodes are good.
                                  Any visible on the primary side?
                                  • J-Pow
                                    • Oct 2013
                                    So was there ever a solution as to what the cause was? Any help greatly appreciated
                                    • pc_doc_al
                                      • Jul 2012
                                      • 45
                                      Tom, where did we leave off? I did replace the Main Power board and now I get a green power led that stays on for about 6 seconds then clicks off. The panel still does not light up.
                                      Thanks,
                                      Steven
                                      • pc_doc_al
                                        • Jul 2012
                                        • 45
                                        Update!
                                        I rechecked all my cable connections and found one that was not secure. It is working great now.
                                        Thanks Tom66 you have saved me once again.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
