Re: HP 50" Plasma TV, Model: CPTOH-0603... plz, need help troubleshooting
It seems strange tho that Vs and Va were at-spec within a volt or so, and I adjusted them to under a quarter-volt error.
I did check the DMM on my car battery, on a few AA batteries, and wall AC voltage. All seemed reasonable.
Do those values for Vy and Vsc seem right? Am I reading the panel sticker correctly? Vy=-200 and Vsc=120 ?
I guess maybe at higher voltage my DMM could be breaking down. Its a Fluke 867B Graphical ScopeMeter.
I would consider the chance that your multimeter battery is low, causing incorrect readings.Leave a comment:
Wierd.
I adjusted Vs and Va per the specs on the panel, they were off maybe 0.5V and 1.5v respectively.
Then the label on my panel shows Vy of -200 and Vsc of 120, right?
The values on my Ysus board were quite a bit lower than this (stupid me didn't even record the as-found values...)
So I adjusted them per instructions to within 0.25V of -200 and 120, with the TV in "white".
Well, got around to the front and found the panel all dark and deep red in color...wtf?
I went back in a panic, and double-checked the voltages, they were -200 and 120 still... ok... something wrong here.
I went and adjusted them to -160 and 80, just as a guess. Panel looks perfect now, no mal discharge at all. No sparkles, TV looks awesome.
I decided to leave well enough alone, and put it back together, lol.Leave a comment:
It can get better with the right combination of tweaks, but it most likely won't completely go away. Trust me, I've tried on numerous LG TVs, as has Tom.Last edited by capkid; 08-11-2013, 11:28 AM.Leave a comment:
I've attached the panel alignment guide.Leave a comment:
Yep.
(covers most LG plasma panels made in the past few years... check the PDP50X1/2/3/4 sticker to determine which panel you've got.)Leave a comment:
Is there a detailed guide on adjusting the voltages before I remove the board for mailing to ya?Leave a comment:
Yep, that's mal-discharge. The good thing is that it doesn't go away when the panel warms. If that were the case, you'd be looking at a panel problem.Last edited by capkid; 08-11-2013, 11:07 AM.Leave a comment:
So just to be sure, here's a closeup video I took of the TV bottom right corner, showing the red snow. Is this what "mal discharge" looks like? Also, the density of the red pixels changes, depending on what is on the screen, but it doesn't appear to change as the TV warms up. Its there the first time you turn it on, and its there no matter how long the TV is on, doesn't get better or worse.Like Tom mentioned, a lot of these LGs need the control boards reprogrammed after the Y-Sus or Z-Sus is replaced to get rid of the mal-discharge. The pixel firing timing gets thrown off by the new parts. I have the LG jig that's used to program the control boards:
https://www.badcaps.net/forum/showth...=mal-discharge
https://www.badcaps.net/forum/showpo...5&postcount=77
Can you post a pic of the pad problem?
http://www.modschat.com/IMG_3539.MOV
I also included a still image.Leave a comment:
Can you post a pic of the pad problem?Last edited by capkid; 08-10-2013, 04:24 PM.Leave a comment:
Firmware ya think? but it didnt have this problem before the failure last week...
I kinda did a crappy job on replacing the FET. I have a broken left wrist, so wife was pulling up the FET as I heated the heat-sink solder, she's a big strong German girl, she peeled the pad off the board with the FET before the solder melted I put the terminals back down on the new FET, but I bet the heatsink it marginally useful, its not staying down. Is the FET heatsink an active terminal for the FET? Could i just ground it with a homemade heatsink? Could this be behind the red pixel sparkling?Last edited by ngc1068; 08-10-2013, 02:53 PM.Leave a comment:
No, i had ordered a complete new bottom board, so I had my old one. I robbed one good FET from it and replaced the one bad one on the top board.Last edited by ngc1068; 08-10-2013, 02:44 PM.Leave a comment:
This is a common issue with this panel, capkid has a repair service (firmware update) I believe...Leave a comment:
a few red sparkles all over the screen tho...hrmnLeave a comment:
I've never seen both the upper and lower boards fail with bad fets. Noted. Nice job on the fix.Leave a comment:
But you have one less FET on one board? You should replace that to make sure it doesn't fail again.Leave a comment:
yay, that did it!!!! its fixed!Leave a comment:
That'll do it.Leave a comment:
yeah, top most FET on upper is badLeave a comment:
This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-06-2024, 05:27 AM
This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
by Mark DI currently (out of necessity) have found myself troubleshooting a Samsung TV: Model UN65JU670DFXZA Version T01. My past has been in repairing antique radios...not new circuits. Here I am very new. The TV would not turn on and did not have a standby light. When I opened the back, I noticed that the power supply board had a blown fuse. While I attempted to search for a short, I found two. Now comes my ignorance...The transistors that I found to be shorted are labeled as: 1E52AH FDPF12N50NZ. The only ones I can find are on Ebay but the top numbers are either 1E16AJ or 1B23BB. Ive never ordered transistors...
- Loading...
