Samsung 42" Plasma PN42C450B1D
  • fatcattara
    • Feb 2014
    • 42
    Re: Samsung 42" Plasma PN42C450B1D
    Yes Tom
      That indicates to me that there is a main board, control board, Y-main/X-main or cabling fault.
      The next step requires you to remove the cover of the TV and perform a simple test pattern jumper - see here: https://www.badcaps.net/forum/showpo...61&postcount=2
      You should get a loop of test patterns when the TV is powered on. Note, the user menus, interface etc. won't work, but you should still be able to turn the TV on and off normally.
      Leave it powered on like this for some time. Does the screen still go blank?
      • fatcattara
        • Feb 2014
        • 42
        No picture (video) after placing jumper and disconnecting the ribbon cable
          At all? Did you take TV out of standby using remote?
          • fatcattara
            • Feb 2014
            • 42
            no, I pushed the "panel-on"
              I'm not sure what that is? You should just turn TV on normally, with remote, as if it were working.
              • fatcattara
                • Feb 2014
                • 42
                This time I powered on using the remote control - same results, no video at all (total black screen; sound is OK
                  Please show me how the test pattern jumper was done and which cable you unplugged - Very odd results.
                  Any light on control board flashing? Once a second or once every 5 to 7 seconds?
                  • fatcattara
                    • Feb 2014
                    • 42
                    How can I upload a picture?
                    • fatcattara
                      • Feb 2014
                      • 42
                      The green light on the board blinks slowly on- off
                        Use the Manage Attachments button.
                        • fatcattara
                          • Feb 2014
                          • 42
                          I just restored everything - no picture either; perhaps it needs to be powered down longer?
                            I'd make sure every cable is fully seated properly...
                            • fatcattara
                              • Feb 2014
                              • 42
                              After turning it on and off several times, I got now a picture in red
                              • fatcattara
                                • Feb 2014
                                • 42
                                I verified the cable was in proper
                                • fatcattara
                                  • Feb 2014
                                  • 42
                                  I'll let it run now for a while to see if the "red picture" also disappears
                                    Really need to see a picture to understand what's happening - if needed upload to your favourite image site (imgur, tinypic, photobucket...) and link here.
                                    • fatcattara
                                      • Feb 2014
                                      • 42
                                      http://s34.photobucket.com/user/fatcattara/library/
                                      I'm new at this, I hope you can see it
                                      • fatcattara
                                        • Feb 2014
                                        • 42
                                        Could it be the two relays on the control board that might cause me the grief (dirty or pitted contacts)?
                                          One of two possibilities, an X-main board fault or the cable between the control board (with the LED and jumper on it) and main board is not fully seated.
                                          I've had an intermittent X-main board on this model before (well, B450, but it's the same panel...)
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
