Samsung 50" 850fh-yb06 Y-SUS
  • sharptrain
    • Jul 2013
    New to the board and new to Plasma troubleshooting.. Based on what I've read my problem stems from the Y-Sus card (sound, no picture).. I attempted to check the fuse on the card.. Alas there is none that I can locate.. The card is lj92-01728a, I've attached a few pictures of the card.. There is a signle ceramic fuse on the power card which checks out fine, but I can't seem to locate any others anywhere else. I don't want to replace the entire y-sus card before I determine the card is the issue and that the proper fuses check out. As previously stated I am new and have probed previous threads but I've hit a road block here! Any help at all would be appreciated!
    http://i.imgur.com/vspilvP.jpg
    Edit: Apologies. , title should have read SAMSUNG PN50C590G4F .. Had the cover off and read an erroneous model #
  • nader_guesmi
    Samsung UE65TU7172 – BN41-02751C – CI+ ECP Keys Missing / Digi Card Not Working
    by nader_guesmi
    Hey everyone,
    I’m working on a Samsung UE65TU7172 with mainboard BN41-02751C. The TV powers on normally, I’ve applied the latest software update, and all measured voltages are correct.
    Problem: The CI+ module doesn’t read the Digi card.
    I accessed the service menu (using Mute + 2 + 4 + 7 + Exit) and ran the CI+ test. The results show:
    • CI+ production keys: Success
    • ECP keys: Not installed
    So the TV doesn’t even attempt to communicate with the CAM/card.
    I’ve tried multiple Digi cards (both old and new), and they work fine on another...
    09-09-2025, 03:04 PM
    09-07-2024, 05:50 AM
    09-06-2024, 11:40 PM
  • PlasMatt
    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
    by PlasMatt
    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
    09-20-2025, 06:50 PM
