Samsung LA32R81B Washout pictures
  • mikecarel
    • Jun 2013
    • 11
    • philippines
    I've got problem with my samsung LCD with model number LA32R81B, Its now having a washout pictures when powered on and normalized after 2 minutes. Tried to check everything on its power supply (even change all capacitors)and found no faults on it. Please refer to link below for the clearer view of the problem.
    http://i1210.photobucket.com/albums/...627_205034.jpg
    Hope someone clearly guide me to identify the root cause of this problem.
    Tnx,
    Mike
    Re: Samsung LA32R81B Washout pictures
    This is possibly an incorrect setting on the main board. Have you tried a factory reset? If not, it may be AS15G gamma chip failure.
    • mikecarel
      • Jun 2013
      • 11
      • philippines
      Hi Tom,
      I've tried reseting it to factory settings via Service Mode, but still the problem persists. It seems that when the TV get's hotter the pictures went back to normal, but when you powered off the TV for 30mins the problem goes back again.
      Tnx,
      Mike
        That does sound like AS15G chip. Please post a picture of the T-con.
        • mikecarel
          • Jun 2013
          • 11
          • philippines
          Hi tom,
          You are right that the problem was in the t-con, using a x10 magnification lens I found a cold solder around the as15g chip. This was the cause of washout picture at cold start.
          Thank you for pointing out where to start troubleshoting this problem. Its now ok after resoldering the cold areas.
          Tnx,
          Mike
            Usually it's not just cold solder - the actual chip fails. If the problem comes back, you will need to replace that chip. It's available for around $5.
            • GadgetmaNZ
              • Feb 2013
              • 6
              • New Zealand
              I diagnosed it by using cold spray.
              What I might try is to make a small heat sink to make it run cooler. At least for testing purposes until I get a new chip.
                09-07-2024, 05:50 AM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
                Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 06:20 PM
