LG 42PX3RV-TA Sound, no pic, YSUS causes shutdown to standby
  • BAM
    • Oct 2009
    Hi, been lurking amongst some of the other threads but so far haven't had any luck.
    I picked up a couple of non working 42" plasmas, and LG 42PX3RV and Hitachi 42PMA300A, both with the usual sound but no picture. Gave up on the Hitachi as decided not worth the time or money to fix a low res set in my opinion, but would be good if could get the LG up and running.
    When I got the LG most of the fuses were missing, from PS, ZSUS and YSUS.
    After replacing them none have blown, but if YSUS is connected, the unit powers on for a few seconds with green led, then switches off again to standby red led (power supply protection mode I guess?) If I run without the YSUS fuse it doesn't shutdown and the main board has 2 LED's lit, sound is ok.
    The PCBs are dated 2006/01 so guessing not due to the design flaw.
    Va, Vs and 5V are ok.
    So guess its a YSUS fault right? IPM? Any suggestions where to look next?
    I've got the PCBs from Hitachi, but they are 42V6's, not 42V7 like this model. The Hitachi powered on ok, all voltages seemed ok and no fuses blew despite no picture.
    Do the 42V6 and V7 use the same IPM on the off chance the Hitachi one is ok?
    Also is the missing cables from P803 and P804 on the PS, and P1101 on the main board normal?
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
  • Jack828
    Hitachi 42HXT12U - Not working - Standby LED Flashes
    by Jack828
    Hello fellow tech geeks!
    I've recently come into possession (a freebie!) of a Hitachi 42HXT12U LED TV which does not work.
    It does the following:
    - Plug in
    - Standby LED flashes alternating RED and BLUE approx 6-7 times
    - Does this approx twice
    - Standby LED stays solid BLUE
    I've opened it up and had a look at the PSU board (which is a 17IPS20 23145828) for any bulging caps and there aren't any.
    Any ideas folks? If you suggest replacing the PSU board then I'll go ahead and do it - only about 30 quid off...
    12-13-2020, 09:14 AM
  • Crystaleyes
    Samsung BN44-00259A standby question
    by Crystaleyes
    Hi all.
    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
    08-11-2023, 05:15 AM
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
