Samsung PN50A530S2F Plasma Clicking Transformer BS
  • Kridian
    • Sep 2010
    • 39
    So here it is, my current obstacle to more outdoor sunshine. Trying to get this Samsung PN50A530S2F Plasma TV going for a friend of mine and need some guidance on what to try next.
    The TV is exhibiting the (popular) transformer clicking when powered on. The screen comes on briefly in a dark grey tone, then off again. No sound at all. Green lights on the Logic Board flash during this cycle.
    Replaced a few caps on the Power Board (none looked bad but you never know*) as well as all the ceramic fuses throughout all the boards (PW, Y & X) but to no avale.
    I did the process-of-elimination by unplugging each board connector from the Power Unit. The TV stopped clicking when the Main Board (A/V) connector was the only one unplugged.
    I have a DMM & a heat gun (if it's going to come to heating up the Main Board for the solder to reflow) so I just need the next logical step in this procedure.
    Thanks in advance!
    Re: Samsung PN50A530S2F Plasma Clicking Transformer BS
    Can you try this test?
    https://www.badcaps.net/forum/showpo...61&postcount=2
    • Kridian
      • Sep 2010
      • 39
      In step 4 of those instructions it says, "Unplug the LVDS cable (see below)".
      Is the LVDS cable the connector going to the Main A/V Board?
        Yes. In your case, it's the one on the right with the thin blue and red wires.
        • Kridian
          • Sep 2010
          • 39
          Ok, test done. The screen came on solid white, then green and then it clicked off. Repeated.
          Next line of attack?
          • Mt.Man
            • Jun 2012
            • 53
            Panel test is good, you have a bad main board.
              Very common with these models. Not certain how to fix it, other than replacing the main board.
              • Kridian
                • Sep 2010
                • 39
                Roger that. Thanks for the help on this.
                • Kridian
                  • Sep 2010
                  • 39
                  The new Main Board didn't work. I'm stumped.
                  Unplugged just the Main Board's connection to the Power Board and the clicking stopped... just to confirm... again.
                    There is a small, quite rare chance that the control board can cause this.
                    Does the control board have a VSON and PSON label on the connector going to the power supply... will be indicated on power supply side usually.
                    • Kridian
                      • Sep 2010
                      • 39
                      Yes.
                        OK, do the 3-4 jumper this time, but unplug the main board power connector, leave the control board power connected. Does it do the same thing?
                        • Kridian
                          • Sep 2010
                          • 39
                          What about the LVDS cable? Is that still attached or detached?
                          *Edit*
                          Main Board power connector detached + LVDS detached gives no panel lighting and no relay clicking.
                          With LVDS attached, same as above.
                            You may need to acquire a 100 to 470 ohm resistor to turn PSON on the main board connector on.
                            • Kridian
                              • Sep 2010
                              • 39
                              Which type?
                              100Ω, 200Ω, 300Ω, 400Ω & 470Ω?
                                Typical; any value from 100 to 470 ohm is fine.
                                • Kridian
                                  • Sep 2010
                                  • 39
                                  Here are the resistors from my order. Are the small ones going to be a problem?
                                    Those are fine. You only need one value .
                                    Connect whichever value is your favourite from PS-ON to GND, and one from VS-ON to GND. Check if Vs/Va appear and if 5V etc appear.
                                    • Kridian
                                      • Sep 2010
                                      • 39
                                      Am I connecting this resistor(s) to the white coupling while it is attached? If so, how do you seat the legs of the resistor so they are not so loosey-goosey?
                                        You can disconnect the connector from the main board end and put the resistors in the holes there.
                                          09-07-2024, 05:50 AM
                                        • unimatrix93
                                          Replacement transformer for Samsung fridge
                                          by unimatrix93
                                          Dear forum
                                          My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                          No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                          The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                          My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                          07-14-2025, 02:16 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
