Insignia NS-PDP50HD-08 / Samsung PN50A5nn
  • kartwood
    • Dec 2012
    • 18
    This set comes on long enough to display blue screen and OSD then shuts off. The SMPS is one which flashes error codes. (4 flashes-Vg). I'm guessing this could mean over voltage or over current.
    I tried to narrow it down by disconnecting stuff and discovered that if I pull any one Y drive connector going to the panel, the set would work fine save the missing part of the picture.
    I had a good Y-Main on hand and that didn't make any difference. I have include a couple of pictures. Thanks!
    Re: Insignia NS-PDP50HD-08 / Samsung PN50A5nn
    Vg is the 15V or so supply from PSU to Y- and X-main. Could be failing buffer causing the issue as 15V is used for buffer boards. But that would usually be only one channel. Try to monitor Vg voltage before & while it is malfunctioning.
    • kartwood
      • Dec 2012
      • 18
      Thanks for the help! The situation has gone from bad to worse. Even with all of Y cables disconnected, it will not come on. It just starts up then after a second, it flashes the Vg error. It comes up to 14.8 volts.
      I have disconnected both the X-Main and Y-Main so there is no load on the Vg at all. It still shuts off with the same error. I suspecting the SMPS now but don't have spare.
        Where is the LED that blinks on the PSU?
        Part number of PSU e.g. LJ44-xxxxxx?
        • kartwood
          • Dec 2012
          • 18
          The PSU is an LJ44-00145B. It is also marked 50WF3. The error LED is LED8001 and is locate just above the connector for the logic pwb. It is almost the same as a Samsung BN44-00222A.
          I was mistaken about the error. 4 flashes is actually Vs. I need to get stronger reading glasses.
          I believe this means that the logic board removed the Vs_on signal.
            09-07-2024, 05:50 AM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 06:20 PM
