Erratic ESR Readings on Antek Blue ESR Meter
  • SgtRock
    • Feb 2012
    • 175
    Greetings BadCappers:
    --I have a question about Capacitors and ESR. I am using an Anatek Blue ESR Meter to measure the ESR of a bunch of caps in a RCA DTA809 TV Converter. I measure the Capacitance and ESR in circuit and then I measure the same out of circuit, keeping careful track of the measurements, specs, location and size of the caps.
    --Most of the caps show a rock steady ESR. But, on some the ESR measurement jumps around both in and out of the PCB. But it never gets so high as to fail the cap for ESR. I have a 10 V 470 uF, and the ESR jumps around between 0.10 to 0.40 Ohms erratically. Please tell me that this cap is bad. I have another one, 16V 220 uF that only jumps around between 0.39 to 0.43 Ohms, that I am even less sure about. None of the caps are bulged or abnormal looking in any way.
    --This converter had the blinking light, and would not turn on. Temporarily, I was able to get a steady light and turn on, by warming the caps gently with a heat gun, so I am pretty sure I have a cap problem. I plan to replace them all. But, I am hoping that someone with more experience than I, will comment on the erratic ESR.
    "An expert is a man who has made all the mistakes which can be made in a very narrow field."
    Niels Bohr 1885 - 1962
    Best Regards
    Clear Ether
    Re: Erratic ESR Readings on Antek Blue ESR Meter
    Both of those caps are suspect, they should measure less than 0.04 ohms in my opinion.
    Shame that the US government didn't insist on a minimum 10 year warranty on these items, after all, most were given to unaware people under the converter box scheme, and they are rapidly dying. Just built to fail...
    • SgtRock
      • Feb 2012
      • 175
      Dear Tom:
      --In saying they had not reached the fail point, I was going by the diagram that came with the Anatek meter. I know from looking at the other caps that these started out life below 0.10 Ohms ESR, so I agree with you they are hinky.
      --Hypothetical question: What if the same caps had a ESR jumping around erratically between 0.10 to 33 Ohms? Or say between, 25 and 30. I am used to the ESR moving a last digit or two? But I am talking about moving around erratically 5 digits or more. Can I use that as a failure check mark? As usual I appreciate being able to pick your brain, or anyone's for that matter. Thanks.
      "Measure twice. Cut once"
      Norm Abram 1950 -
      Best Regards
      Clear Ether
        A cap should hold a particular ESR; if the reading is that erratic, then I'd consider the probes or meter to be at fault. Try cleaning probes and zeroing meter.
        • SgtRock
          • Feb 2012
          • 175
          Dear Tom:
          -- As I said at the beginning of this post. "Most of the caps show a rock steady ESR. But, on some the ESR measurement jumps around both in and out of the PCB." Tai'nt the probes.
          "He didn't know where he was going. But he knew where he was wasn't it."
          Lord Buckley 1906 - 1960
          Best Regards
          Clear Ether
            Very odd- perhaps the leads of the suspects are contaminated or dirty?
            • jma46
              A1707 820 281 jumps from 5v -16v on amp meter then restarts
              by jma46
              Hi sorry to Hijack this thread, I have an A1707 820 281 which jumps from 5v -16v on amp meter then restarts, I have checked big coils for shorts, ppbus and all seems ok. Im thinking there is a short which is causing it to reboot but I'm out of ideas? Also another A1707 where the internal SSD is not showing in terminal or disk utility? No excessive heat from SSD chips?
              Thanks in advance for any suggestions...
              08-13-2024, 03:18 AM
              Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
              This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-07-2024, 05:50 AM
              Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
              09-07-2024, 05:00 AM
              Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
              Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
