Samsung HP-T5054 ysus and buffers
Re: Samsung HP-T5054 ysus and buffers
With regard to the meter possibly not revealing secondary damage to the transistors, are you saying that this type of damage would only be evident in a typical live circuit, or is it dependent on the quality of the meter? I typically use my Fluke 87 III to test.Comment
To add: I found what appears to be the same damaged FETs as JeffJ - One K2837 FET, one 88N30W FET, and the burned B20NK50Z FET.Comment
One user discovered their board tested OK, but that when they applied a voltage of 5V, it drew around 50mA; at 12V, it drew about 200mA, and it quickly got worse.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
So, is this why you're advocating replacing all five FETs in the bank of FETs on the heat sink? Has this proven to resolve the issue? The second T5054 I picked up a couple days ago appears to be exhibiting the same FET failures as the first one I picked up.Last edited by capkid; 02-04-2013, 04:09 PM.Comment
Usually I'd replace all FETs in a bank where one failed. If they're in parallel damage could have been done to the others. FETs are cheap, buffers are not.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
. I'm going to go ahead and replace all of them.
Also if the FETs are used for the sustain portion (positive and ground), I'd replace both upper and lower FETs. If they are for ERC (energy recovery) or Yrr/Yfr I wouldn't usually do so.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
How do I find the wattage of the surface mount resistors? Is there a standard wattage that's used with these TVs? I don't have a service manual with a parts list.Last edited by capkid; 02-04-2013, 06:15 PM.Comment
I wish there were a way to edit an older post (unless I'm just unaware of how to do so). Anyway, it looks like the resistors are fine. Once I removed the damaged B20NK50Z FET, I was able to get more accurate resistor readings. How does this pad look from the front side of the board? The gate and source pads are fine.Comment
Looks OK, clean it with some flux before soldering though.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The more I examined it, the portion in the middle of the pad is burned through a good deal of the PCB. I scraped some of it away, but I didn't want to go too deep. I'm a little concerned about a burning odor being given off when the TV is operational. I did solder on a new mosfet after cleaning the pad with alcohol, but I can redo it if necessary.
I saw this PCB repair procedure online, but I'm not sure I need to go this extreme: http://electriciantraining.tpub.com/.../14186_128.htmLast edited by capkid; 02-05-2013, 12:40 PM.Comment
It's only going to burn if it's got a fuel source. If that is just contamination it'll just make the MOSFET run hotter.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok. I'll just leave it as-is for now and see how it performs. Would a small heat sink help? I'm not sure I can find one that small or if it would make that much of a difference.Comment
Probably not going to work that well... then again I have seen Panasonic do it on their new thin plasmas (1" thin, all SMD) so maybe it could work.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Changing those ICs isn't fun, either. The good thing is that the last T5054 I picked up came with a set of working buffer boards and an extra working lower buffer board. The previous owner kept saying, "I read online that the Y-Sustain board goes bad, so I changed BOTH of them. The TV's still not working." LOLComment
vent tried to change the icu s yet i want to get a hot air station,, and try to change them,,that would be the cheapest route,,or get someone on here to do it 4 me.thats prob gona be my next thing i'm going to order is a hot air station,,but not sure what kind yet,,been looking at xtronic and 2 other kind.Comment
I found this blog post by Coppell TV Repair - I'm figuring it's been brought up previously, but I didn't search the forum. He mentions that early Samsung plasma TVs usually have the buffer(s) fail, which also causes the Y-Sus to fail: http://blog.coppelltvrepair.com/2011...d-buffers.html
Was there a known design change that caused the opposite to happen? I'm a bit reluctant to fix and resell one of my HP-T5054s without changing out all buffer chips or the boards themselves. I know it can be an expensive proposition. I saw what appeared to be a Philips I'd sold on CL a couple months ago that failed recently and was being sold for parts. I had the Y-Sus done by Coppell, but a replacement buffer board came from a parts TV I had.
Edit: Better link: http://blog.coppelltvrepair.com/2012...d-with-no.htmlLast edited by capkid; 02-12-2013, 02:11 PM.Comment
I attached a heat sink to the mosfet using some compound and Momentive RTV. I'm letting the RTV cure overnight. I also used some 2000-grit sandpaper to gently clean up the burn marks on the PCB. I scraped away as much of the burned PCB underneath the mosfet as I could without making a hole through the board. Thoughts?
vent tried to change the icu s yet i want to get a hot air station,, and try to change them,,that would be the cheapest route,,or get someone on here to do it 4 me.thats prob gona be my next thing i'm going to order is a hot air station,,but not sure what kind yet,,been looking at xtronic and 2 other kind.Last edited by capkid; 03-01-2013, 06:16 PM.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by leggLG42PC3D -UD originally with green lamp but no display or audio.
Owner says was working, then went 'pop'.
All 5V caps bulging. replaced.
All PSU output voltages within spec but -Vy is low on YSUS.
One of three parallel fets between SUS_OUT and SUS_DN is zenering,
eventually shorts DG. Replaced all 3 - -Vy now OK.
Y scan buffer test point does not follow YSUS output below -50V
Note: This unit seems to expect YSUS output to park at -Vy in between
drive signal pattern periods. A replacement drive signal board confirms this....11-18-2021, 11:49 AM -
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
