Samsung pn58b860 Clicking
    Re: Samsung pn58b860 Clicking
    I doubt it. The PSU appears to work, the main board is shutting it off.
    • ptheman12345
      • Dec 2012
      • 42
      • usa
      #42
      okay, I'm going to go ahead and order a new main board. Hopefully thats the cause of the problem
        Do you want to check if the other boards are OK using the resistor trick?
        • ptheman12345
          • Dec 2012
          • 42
          • usa
          #44
          yeah, how do i go about doing that?
            Wire a 100~470 ohm resistor from PSON to a GND pin. Disconnect the connector from the main board but leave the end plugged into the PSU connected.
            The TV should switch on as normal and the voltages should come up.
            Then, turn it off, try one jumper combination on the control board, turn the TV on, and repeat until you see patterns, if everything except the main board is working you should see patterns.
            • ptheman12345
              • Dec 2012
              • 42
              • usa
              #46
              Finally found time to do the test and here are the results: After using a 330 ohm resistor and following your steps, I got the colored test patterns after jumping pins 3-4 on the control board. Just placed an order for a new main board. I'll report back with the results after it comes in. Man, I hope it works!
                The test you did proves that the plasma panel, control board, sustain boards and power supply are all functioning correctly. The only missing link is the main board, and that's likely the fault. Good luck!
                • Talladega
                  • Jun 2014
                  • Usa
                  #48
                  I am having the same problem but the ceramic fuse the you were checking first is not getting power. What should I look at. I know nothing about this stuff. Any help please
                  • trainman1124
                    • Oct 2014
                    • 3
                    Tom66, and ptheman12345,
                    I just want to thank both of you!
                    I was able to follow these instructions and reproduce the same issue and get the test patterns to display by using a resistor to short out PSON to GND, and also jump pins 3 and 4 on the control board.
                    I just ordered a new main board and am hoping that it'll bring my TV back to life. If it wasn't for this guide I would have spent a lot more money on a new TV.
                    Thank you again!
                    Nick
                    • trainman1124
                      • Oct 2014
                      • 3
                      New main board in, and the TV is working!
                      Thank you both again!
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
