Magnavox 32md359b/f7 White Screen and with sound only
    Re: Magnavox 32md359b/f7 White Screen and with sound only
    Originally posted by YEROC37 View Post
    We have no sunlight here, you must be on west coast, let me know if this is ok
    I'm in a little place called the UK, I think we had a disagreement sometime around 1776 about independence or something.
      I was just working on that, just noticed only one is sizing
        testing this one
          Wow much better I think
            Looks good. I am heading off to bed soon. I will have a look at this in the morning when I get a chance.
              tom I believe these shall work sir
                OK couldn't resist - got to sleep soon though! Which end of the the board plugs into the LCD panel (it will go up into the metal frame, possibly onto another board) and which end into the yellow/orange boards?
                  the last pic shows the flat flex, that is it
                    All three go to the LCD?
                      CN3902, it sits at base/bottom
                        No, it's the single flex in the pic...its on the right hand side
                          Odd arrangment; the other two go to the yellow boards? I'm trying to figure that out, have the bent the cables over for one set?
                            No the three go to the power supply board and the flex flat cable that is off to right side by itself goes to the LCD
                              Oh OK. That cable is just smaller than I expected for the kind of data but this TV is designed in a unique way.
                                There are two flex cables going to that LCD ...One from Inverter board and the one which is shown on the system board in the pic above
                                  Is the board on the LCD just a long thin strip? I am hoping it might have a fuse, but I don't think it will.
                                    Yes it is
                                      I see no sign of a fuse on board,
                                        Hmm, you are getting sound, so most of that SupraHD chip is working. I think the only possibility is something on the LCD isn't working right. But they included no fuses... There are some drive voltages, -6.8V, +16V and +22V. These are available on CN1001, which goes to the inverter.
                                        -6.8V is at C202 - a little beige/brown disc probably.
                                        +16V is at C201 - similar
                                        VGH is pin 10 (22V) or possibly Q201 (one pin should measure 22V, the other, 24.4V, and the other 23.9V according to schematic.)
                                        Please verify these are good and present.
                                          Thanks tom, I am on it now checking
