42" Samsung plasma acting strange
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Uh oh!
    Our TV just started displaying random colors and stuff and lines on the screen. I was like, oh NO, its dead!
    I unhooked the HDMI and used the RCA video, and it is working now.
    BUT, now there are bands of white haze slowly going up the screen. Could there be a bad capacitor in the power supply messing up the scan rate?
    I tried restarting the cable box (DVR) and it didn't change anything. I might try using the DVD player tomorrow.
    I will try to get the model for you later.
    -Ben
    Muh-soggy-knee
    Re: 42" Samsung plasma acting strange
    Pics of fault, or it didn't happen! It does sound like a capacitor fault - as freezing pictures/graphical glitches are occasionally reported symptoms when caps go bad on Samsung TVs.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Er, other family members are using the TV right now, I might be able to get pics in about 15min.
      I'm guessing it is a badcap, b/c I didn't replace all the CrapXons (shame on me!) in the PSU when I had to fix it before ( failed mosfet ).
      Muh-soggy-knee
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Ok, here are some pics.
        I managed to pause a show in between the commercials, so the screen was black. You can see the white fuzzy stripe, and it just slowly climbs upwards.
        I took two pics of the HDMI issue, one when the screen flashed pink, and another when it showed some random garbage.
        Its almost like the video processor is crashing, and then showing junk on the screen.
        Also note the burn-in on both sides of the screen
        Sorry if the pics are a bit blurry, our living-room doesn't have much lighting in it, and its dark outside now. And to make it worse, the TV is very bright, so the camera has a hard time focusing.
        Muh-soggy-knee
          Looks almost like a Y-buffer problem, but possibly bad caps too.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Aw, why?
            I think the video processor keeps crashing, and then it display random junk.
            It will flash random things on the screen when trying to receive an input signal from HDMI.
            It works without the artifacts using the RCA input. But there is that stripe going up the screen. I'm thinking some 60hz ripple is causing the video processor to crash, and making the scrolling bar on the screen.
            The model number is: HPT4254X/XAA
            The thing is, this happened all of a sudden, so it might not be a badcap issue. Unless one went open circuit at once.
            Muh-soggy-knee
            • crashp3
              • Mar 2011
              • 81
              Do you have pictures of the T-CON? This likely has diag jumpers to display test patterns with the mainboard out of the equation to determine if it's the video processor (on mainboard) crashing, or a buffer problem.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Plasma Tv's don't have a T-con
                Muh-soggy-knee
                • crashp3
                  • Mar 2011
                  • 81
                  my apologies... the LOGIC/CTRL board.. and I just confirmed with the service manual for the set, it does have the 4pin diag header on the LOGIC/CTRL board.
                    Yes, they do. Sometimes called the logic board. But they also need a timing controller.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Ah good, well I might be able to open it up later, we will be busy today, so if not then tomorrow I might be able to get it open.
                      I will try it with the DVD player and see if it has the same problem.
                      Muh-soggy-knee
                        The reason I said it looks like a Y-buffer issue is that graphical glitches such as repeating patterns can sometimes be caused by a bad Y-buffer. A Y-buffer is responsible for driving the whole line and with correct timing; if it gets confused you will get noise on the screen.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Then why would it work ok (except for the white scrolling haze) on the RCA input? Would it be because of the resolution?
                          Muh-soggy-knee
                            Probably bad caps then or some other video controller issue.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Hopefully its not something expensive, it just started doing this all of a sudden, but no pops, or smells.
                              Muh-soggy-knee
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Well, what do ya know!
                                Its NOT the TV, its the fu&#*^! HDMI cable. We have bought cheap ones, and expensive ones, and after a year or two they break inside and we have to get a new one.
                                We were just about to take the TV off its mount and I did have it turned on to show everyone else what it was doing. I went to grab the HDMI cable and the picture went back to normal off a sudden! I wiggled the cable, and sure enough the picture flickered too. Damn crappy cables.
                                Muh-soggy-knee
                                  Some cheap cables are okay, others are poor. Currently using a cable bought for £1 with Full HD picture at 50Hz, no issue. HDMI, 1 metre. I find it hard to believe TBH; I suspect you have a cold joint on your main board and wiggling HDMI has fixed this.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Its actually in the cable itself, I tried turning it around and it is at one particular end of the cable, it doesn't matter if it is plugged into the TV.
                                    Muh-soggy-knee
                                      And this caused white haze on other inputs?
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Nope, I don't know what is causing that, but it might have been like that for a while, its just barely noticeable.
                                        Muh-soggy-knee
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
