Digihome 37" 37723 HD
    Will be picking this up later tonight.
    It has no picture, that is the description. I expect it will be the typical 15nF cap failure (Vestel rubbish PSU.) May just replace the PSU if it proves too difficult.
    Re: Digihome 37" 37723 HD
    So, got it home. Vestel trash again.
    Immediate diagnosis is a brief WHITE flash from screen then backlight shuts off. Otherwise, set behaves normal - turn on/off fine. Not tested sound, expect that may be okay.
    Now if the screen flash were grey (as in no signal but backlight dying) I would say it is likely an inverter issue. But it's white, indicating the T-con is also not getting proper power.
    Put the scope on the 24V line and when the backlight flickers the 24V drops by 1.5V quickly, probably enough to upset the inverter board. The 5V may do the same thing, haven't tested it, but if it is, it's likely the problem.
    I'm going to try to repair this PSU instead of just swapping it out. Wish me luck.
      Well, I ordered some 15nF caps cheap. But, I just went and checked the inverter. The INV_ON stays on (3.3V) when the backlight goes off. So, checked the transformers, sure enough one is high in resistance. Strange the screen flashes white - there could be a second fault here - or maybe it's so quick I can't see anything on the screen (or it could be snow.)
        Video of diagnosis:
        http://www.youtube.com/watch?v=Wv8Hj...ature=youtu.be
          It's fixed now, it was the transformer. Unfortunately it appears that the screen has some mura in the top corner. This is fixable but I may just sell it as-is as it's not particularly noticeable. It has a CPT (Chungwa Picture Tubes) LCD panel, which is crapppp, so that's probably the reason. Also awful motion blur and crappy contrast.
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
          • tonydix
            Digihome Vestel 500UNDC TV loses picture after a few seconds
            by tonydix
            Vestel 500UNDC using a vestel 17PS20 power board. Backlights come on and picture shows for a few seconds and then goes dark. Sound is fine. Is this a problem with the led strips or the backlight driver ? Many thanks
            11-15-2021, 05:37 AM
          • France_53
            Vestel tv, how to flip the image?
            by France_53
            Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
            05-12-2024, 05:22 AM
          • Strudul
            Digihome 40272SM (Vestel) - Various Issues.
            by Strudul
            I've got a Digihome 40272SM with a number of problems, some of which appear to be intermittent.
            1) Initially, the problem was an intermittent dark patch on the left side of the screen and a single 1 pixel wide black vertical line on the right side. The dark patch seems to have fixed itself, but the black vertical line remains. I'm assuming this is due to a faulty panel, so will just have to live with it (it's not too invasive for the use it gets).
            2) Along with the above, the TV would turn itself off randomly. This only seemed to happen when the dark patch on the...
            04-06-2021, 12:53 PM
          • John McGivern
            Digihome PTDR32FHDS5 (Vestel) 32" LED Smart TV
            by John McGivern
            Above TV, power on, 8 flashes tested all diodes and electrolytic caps ok
            voltages shown on attached photo's. LEDs tested all but one was open so I bridged open LED all light but very dim. Shining torch I can see text on screen but voltage low on led connector. I dont have a remote yet. Any help would be appreciated.
            Many thanks....
            03-05-2022, 09:48 AM
