50" Samsung Plasma (model number PS50Q91HD) - possible purchase
    replied
    Re: 50" Samsung Plasma (model number PS50Q91HD) - possible purchase
    A good place to check would be across that red cap.
  • psmedley
    replied
    Photos of buffers attached.
    The connectors look pretty similar to the Coppell photos...
    replied
    Originally posted by psmedley
    hmmm doesn't look too promising for the buffers...
    Depending which pins I test on the upper board I'm getting either 0, or 5k ohms or 10k ohms.
    lower board on some pins I get open loop, others 0.
    If I need to replace buffers + repair ysus it's starting to get a little expensive and perhaps not worthwhile
    Post pictures of your buffers, maybe you're testing the wrong places.
  • psmedley
    replied
    replied
    I'd throw out the Jackcon caps though! Looks okay.
    Testing for shorts isn't too difficult:
    http://blog.coppelltvrepair.com/2010...er-boards.html
  • psmedley
    replied
    OK:
    Q5500
    Q5302
    Q5303
    Q5304
    Q5306
    all appear to be shorted and Q5501 is blown - so the ebay auction is looking better and better...
  • psmedley
    replied
    Originally posted by tom66
    Check your Y buffers for shorts, it's possible they're okay. Seems like you've got a really tricky set here!
    Any tips on how to check the Y buffers for shorts?
    I must say, this set is really testing by confidence - I was quick cocky after fixing the 32" plasma :P
    I also need to try and work out if Q5501 is the only messed up part on the Ysus or if I should bite the bullet and just order something like http://www.ebay.com.au/itm/271002634287
    replied
    Interestingly, when replacing the bulged 680uf 25v capacitor on the Ysus board, I did notice some dark/brown patches underneath Q5501 which is now blown - so this mosfet has obviously been running hot.
    From what I've read, I should be able to replace this mosfet, however will need to most likely replace both Y buffer boards?
  • psmedley
    replied
  • psmedley
    replied
    I see Y-Sus repair kits like
  • psmedley
    replied
    Well I tried a 72W halogen globe as well and same result.
    Decided to bite the bullet and try it without the globe in series.
    Plugged in the AC, 1 click and silence.
    Tried turning the TV on and got some buzzing from the back of the set, then something went 'pop' with a small amount of smoke on the Y-main board.
    Not sure what the part is in the attached photo (Q5501) - but it doesn't look so good anymore :P
  • psmedley
    replied
    Originally posted by scokljat
    So, you installed all new FET's, diodes and smd resistors?
    Replaced only the FET's that were shorted, and the 1SS184 diodes and resistors related to those two FETs.
  • scokljat
    replied
    replied
    Found a 100W spotlight Unfortunately, when I turn the TV on I get relay clicking and the light flashes on/off inline with the relay.
    The fuse for the mosfets is still good.
    Ideas?
    Not sure about that; try potentially with more lamps. Other than that I'm not sure...
  • psmedley
    replied
    Ideas?
  • psmedley
    replied
    OK it's all back together... just gotta try find a suitable globe on the way home from work tomorrow before I fire it up
    Took the opportunity to replace a bunch of shitty samyoung caps with rubycons too
    replied
    Thinking about it, it might be better to use two 50W in parallel, or equivalent. You can use less, but you can't be sure the PSU will even start up into standby.
    replied
    Thanks Tom - I'll assume that if I can't find a 100W globe, that two globes in series adding up to 100W would suffice?
    That should be fine, just make sure not to use anything with an electronic or magnetic ballast, you -must- use an incandescent or halogen bulb.
  • psmedley
    replied
    Everything should be connected and try to turn the TV on though I'd expect the TV to not power on properly with the bulb in series, but it will prevent a short from causing more issues.
    replied
    Oh, and once I find a 100W globe, when I power it up, should I have all the sub-boards connects to the power supply?
  • porfyriadhs
    Samsung Plasma PS51D6900DS Bootloop
    by porfyriadhs
    Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
    Thanks a lot !!
    10-19-2023, 11:31 AM
  • ArMaaN376
    Samsung PS51E550 Plasma TV
    by ArMaaN376
    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
    Opened TV cover & observed foll
    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
    How to confirm Y -Buffer board...
    06-19-2024, 04:05 AM
  • CDNBrewer
    Samsung Plasma PN43D450A2D No Power
    by CDNBrewer
    Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
    This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
    I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
    When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
    03-02-2025, 04:59 PM
    09-07-2024, 05:50 AM
  • crigab
    Samsung plasma PS43E490
    by crigab
    Hy guys, i have a Samsung plasma PS43E490, with Y-board and X-board defective. I repaired them, but now the problem is that i have sparks on the ribbon cables from the X buffer to the screen when powering up. There is any solution for this? Thanks. ...
    02-02-2024, 08:51 AM
