Re: 50" Samsung Plasma (model number PS50Q91HD) - possible purchase
Someon's just contacted me about their Samsung PS42C7HD clicking - I might take a chance on it if it's just cold joints.
Tried to reply on Saturday but server upgrades got in the way
All transistor readings were higher than 30 ohms, so I'll assume the sub boards are OK.
I do plan on replacing the accompanying resistors as well as the diodes and mosfets before I try powering up again. ie all the parts described in http://www.ebay.com.au/itm/160644626388
I just need to wait for all the parts to arrive now - Adelaide electronics stores suckLeave a comment:
I just do a simple all pins combination to see if they are shorted. For a 3 pin transistor, measure the resistance between pins 1-2, 1-3, and 2-3. Any reading under 30 ohms warrants desoldering and verifying out of circuit.Leave a comment:
I didn't get a chance to actually turn the TV before it shorted. I plugged in the AC, it wasn't clicking, so I made a quick pit stop, came back and it was clicking
Any tips on testing the Q's?
Is:
<quote>
POSITIVE PROBE TO: -----NEGATIVE PROBE TO: -----RESISTANCE READING-- CONCLUSION:
Emitter------- -- Base---------- Less than 150 ohm ------Transistor is NPN
Base --------------Emitter --------Infinity ----------------Transistor is NPN
POSITIVE PROBE TO: NEGATIVE PROBE TO: RESISTANCE READING: CONCLUSION:
-Emitter------------Base ---------Infinity ---------------- Transistor is PNP
Base --------------- Emitter --- - Less than 150 ohm ------- Transistor is PNP
Some defective indications of transistors: Resistance between any pair of the terminals is less than 10 ohms* means that the transistor is shorted. Resistance between base and emitter or base collector for both the forward and reverse application of ohmmeter probes is infinity (meter needle don't deflect)* means that the transistor is open. Transistors overheats (except power transistors) during normal operating condition means that the transistor is shorted.
</quote>
Sufficient?Leave a comment:
Q's and D's can be tested; R's will need to be pulled.
Did TV show any picture before it shorted again?Leave a comment:
OK ordered the SMD diodes retiredcaps suggested.
Whilst I wait for them to arrive, I've been reading http://preher-tv.blogspot.com.au/201...-repaired.html on the other common issues on similar Samsung power supplies.
This mentions components like:
RX802, RX803, RX832 and RX833 are open or have a seriously increased resistance.
RX804 and RX805 are open or have a seriously increased resistance.
These all measure around 50 Ohms in circuit vs the stated values of:
RX802, RX803, RX832 and RX833= 20 ohm
RX804 and RX805= 10k ohm
Is this due to them being measured in circuit??
It also mentions problems on the sub boards:
QS803, QS804, QS805 and QS806 one or more shorted(check for open junctions as well)
DS823 shorted(may be open as well) check between pin 1 and 3
RS859 may be open or have a seriously increased resistance
Can these parts be tested in circuit?
QS803 and QS804= NPN 20V 2A SMD BJT(marking ZG)
QS805 and QS806= PNP 20V 2A SMD BJT(marking ZH)
D823= 18V 0.35W SMD zener diode(marking 8Y)
RS859= 4.7 ohm SMD resistor
Cheers,
PaulLeave a comment:
My only hesitation is the shipping time from the us to australiaLeave a comment:
Need 48 spare? 50 for $6.00 + free shipping
http://www.ebay.com/itm/160586650557Leave a comment:
http://preher-tv.blogspot.com.au/201...-clicking.html suggests "DS801 and DS802 are both 1SS184T5LFT, UFR dual package common cathode SMD diodes" I find these on mouser at:
http://au.mouser.com/ProductDetail/T...sljcLw5w%3d%3d
However RS in Australia has this as a discontinued product:
http://australia.rs-online.com/web/p/rectifier/3174558/
They have a list of 'similar' products - any recommendations?Leave a comment:
The diodes are definitely bad "in circuit". You can remove them and verify out of circuit. You will have to remove them anyway if they are bad.Leave a comment:
Numbered left to right - 1 to 3 - pin 2 is on a side by itselfLeave a comment:
CuriousInventor makes an excellent series of soldering videos.
http://www.youtube.com/watch?v=3NN7UGWYmBYLast edited by retiredcaps; 06-27-2012, 02:49 PM.Leave a comment:
How are you numbering the pins? If pin 2 is the only pin on one side, those diodes are definitely shorted. That means pin 1 and 3 are on the same side. If yes, both diodes are shorted.Last edited by retiredcaps; 06-27-2012, 02:49 PM.Leave a comment:
DS801: (first pin red, 2nd black)
Pin 1-2 = 0.006v
Pin 2-1 = 0.006v
Pin 2-3 = 0.006v
Pin 3-2 = 0.006v
DS802: (first pin red, 2nd black)
Pin 1-2 = 0.006v
Pin 2-1 = 0.006v
Pin 2-3 = 0.006v
Pin 3-2 = 0.006v
So given in diode mode the reverse reading should be open loop I'll say these are bad?
Next question will be any tips on replacing SMD diodes???Leave a comment:
can anyone explain how to test DS801/DS802? it has three pins - not sure how to identify which pin is what.
I get ~10Ohms across the pins and reversing the red/black gives the same value - so I'm assuming they're shorted? as being a diode they should be open circuit the other way around?
Put your multimeter in diode test mode. Measure pin 1-2, then reverse the probes. Measure pin 2-3 and then reverse the probes. You should have 4 readings in total.
In diode test mode, the unit of measure is volts, not ohms. So instead of 10 ohms, you have 0.10V (10 mV). That would be a shorted diode.Leave a comment:
Reading http://preher-tv.blogspot.com.au/201...-clicking.html - can anyone explain how to test DS801/DS802? it has three pins - not sure how to identify which pin is what.
I get ~10Ohms across the pins and reversing the red/black gives the same value - so I'm assuming they're shorted? as being a diode they should be open circuit the other way around?Leave a comment:
uggh mosfets finally arrived from RS today.
Installed them, plugged in tv - yippee - only one click from psu. Went for a quick pit stop, came back and the fuse had blown and the new mosfets are shortedTurns out I'd forgotten to tighten the screws securing the mosfets to the heatsink - however I wouldn't have thought being in standby for a couple of minutes could be enough to blow them???
If it helps, I *think* this is the schematic for your PSU.
Well given the packaging - farnell don't have a suitable replacement... So... it was either ebay from China, the US or the UK, or RS with the parts on backorder.... (and maybe from the UK)
Just wish Jaycar sold mosfets so I could get something today :PLeave a comment:
by porfyriadhsHello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
Thanks a lot !! -
by ArMaaN376Hello,
I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
Opened TV cover & observed foll
a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
How to confirm Y -Buffer board... -
by CDNBrewerHello, I have a Samsung Plasma TV - Model # PN43D450A2D
This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by jshhhHi all,
I have an old Samsung ps51d550 that would power on with no picture. I was testing the voltages on the boards based on some advice I'd seen online, I took off 2 of the boards to try test the mosfets, but couldn't really get at them...I left it a while, came back and reinstalled the boards to do some tests and it started smoking. Looks like it was coming from this ribbon cable (see attached picture).
As you can see, im an absolute novice with this kind of thing but I don't like paying for repairs or buying new stuff if I can fix it cheaper.
do you think... - Loading...
