Re: Toshiba 50HP66 Plasma No Picture Flickering
change video input to an unused one. hit menu - post pic. sounds like a mosfet is shorted on buffer board
we replaced the y sustain board in our toshiba tv and now the screen is flickering and has vertical lines. does anyone have any suggestions as to what we should do next?Leave a comment:
I think it causes direct connect of the Vscan voltage, so the buffer board ends up selecting all lines at once instead of just one. The other way it could fail is open, unlikely, which would lead to a dark screen.Leave a comment:
you were right - had one blown mosfet (FQB46N15TM) - set works perfect again. These sets have a fairly good pic - one negative is the amount of screws to remove the back cover and the weight ! thanksLeave a comment:
I have this set 50HP66 and have the curtain bar (when menu pressed - vertical bar about 5-8 inches wide down screen, rest of screen is black). I've seen other posts about this - like u said its the y buffer boards. How does the buffer board cause this display ??? thought when buffer chip on buffer board goes out - causes horizontal line ??Last edited by capkid; 08-08-2013, 09:03 PM.Leave a comment:
I have this set 50HP66 and have the curtain bar (when menu pressed - vertical bar about 5-8 inches wide down screen, rest of screen is black). I've seen other posts about this - like u said its the y buffer boards. How does the buffer board cause this display ??? thought when buffer chip on buffer board goes out - causes horizontal line ??Leave a comment:
His/her last post was over a year ago. I can't make out the "curtain bar" in the video, but it was most likely due to a bad buffer board if it was a vertical bar. Bad Y-Sus IPM and bad Y-buffer.Last edited by capkid; 08-06-2013, 10:36 PM.Leave a comment:
lplaza - did u ever find the fault ??? On your video - display is flashing but when screen comes on - has curtain bar on right side of screen. I'm thinking you have more than sustain IPM problem.Leave a comment:
Picture issues are common with these TVs; I've worked on a few of these 50" Toshibas. Replacing the IPMs and any blown fuses usually corrects the issue. However, a thorough diagnosis is advised before spending money on parts. These IPMs run about $40 each, and it's recommended that all four be changed at the same time (two on the Y-Sus and two on the Z-Sus). Some people do just change out the IPMs on the problem board only.Last edited by capkid; 07-27-2013, 05:20 PM.Leave a comment:
Did you resolve this issue? and if so, can you finish the thread by explaining how? TYLeave a comment:
I can use a y sustain board (on left side). if still available - please send pic of board (both sides) thanksLeave a comment:
I have this tv and it was just confirmed the screen is what went out. I have a tv full if good parts available to anyone in need since the screen is too expensive/impossible to fix.Leave a comment:
A flashing on the display (usually accompanied with a quiet yet prompt "ticking" coming from the YSUS) is a very reliable indication for a failed ER IPM on the YSUS board.
I do NOT recommend replacing only the YSUS for reasons I have explained at length in several articles , including at our blog http://blog.coppelltvrepair.com.
You can actually get some additional details about this failure here:
http://www.coppelltvrepair.com/p/205...repair-service
And also:
http://blog.coppelltvrepair.com/search?q=50hp66
Hope this helps.Leave a comment:
Probably the Y-sus SUS-IPM or ER-IPM. They are about $30 each but require a good soldering iron to replace.Leave a comment:
I am having the exact same problem with my tv. Did any of you find out what the fix was before I buy a new TV. I really like the picture and decent sound from this TV it lasted around 6 years would like to get more years if possible. Thank you.Leave a comment:
Hey guys I'm trying to troubleshoot the same issue. Can someone show a pic of the where the z-sustain plug is? The terminology is killing meLeave a comment:
Thanks guys, will start trouble shooting.Leave a comment:
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...09-06-2024, 05:33 AM
- Loading...
