Help identifying conector in a LCD video camera
  • radud5
    • May 2006
    Help on identifying what represent pin 1 to 13 (particularly +B) on conector LCD to system control on Hitachi VM-E535LE.
    My specify y have only LCD monitor. I desire connect this LCD single to analog video source.
    Thnx.
  • arneson
    • Sep 2005
    • 1267
    Re: Help identifying conector in a LCD video camera
    That's an interesting project.
    I have a collection of older video cameras and would like to find some use for the parts like that.
    I can't help with your answer but would like to know what you end up with.
    Jim
    • japlytic
      • Oct 2005
      • 2086
      There seems to be no info on most of the large ICs.
      5V6 is a 5.6V power supply.
      +B (LCD) should be around 7.1V, according to a measurement on one of the transistors via an inductor on this line.
      LCD NOR/_HI has something to do with the backlight intensity control.
      LCD-VIDEO is Composite Video Input, or possibly Y (Luma).
      LCD-C is most likely to be C (Chroma).
      /HD is Sync for the Character Generator (not likely to be useful for your application).
      With LCD-HOLD and ADDV+SQ, try connecting them to GND or +5V via a 1K resistor (in 4 possible combinations), and note your results.
      /LCD_REVERSE and SP. VOL are of no use for your application.
      Good luck!
      I have also adapted a third-party PSOne LCD (RGB type) to a TV tuner box for computer monitors (the PAL 15.625 kHz RGB and Sync signals were fairly easy to find!)
