Long story short:
Got it for free a couple months ago. Initial symptoms: it would turn on, display "dynamic snow" in the background, and one or two (nested) windows/boxes of "static snow", for a few seconds, then the backlight cuts out, then it comes on again (same snow) for a few seconds, and so on.
PSU was full of Capxons, so a recap was the first step. Result: no change.
Got a new signal board today. Stuck it in, turned it on, got the "booting chime", and vertical rows of garbled colours. LVDS cable is fine. Now i'm starting to suspect the TCON board
With the new mobo, it DOES respond to remote key presses (menu, source, arrows), but you can't make anything out on the screen. It's like only one row of pixels is taken into account, and copied onto all the rows...
Any ideas?
I can provide pics, if needed.
Later edit: I also tried starting the tv without the CI-board, and a red error window (i suspect, since i can only see vertical lines) showed up, with something white glowing/flashing.
Any ideas?
I can provide pics, if needed.Later edit: I also tried starting the tv without the CI-board, and a red error window (i suspect, since i can only see vertical lines) showed up, with something white glowing/flashing.
