LG 42PC3D-UD plasma problem
  • Sirmike
    • Nov 2011
    My samsung pn50a650 plasma went out the same week as my brothers
    LG 42PC3D-UD plasma
    My Samsung is still under warranty by 20 days of a 3 year warranty talking about cutting it close. Anyway this post is for my brothers lg plasma
    After reading a few post it seems theres a issue with this model ... I have read a few post and I haven't found one similar to the issue mine is having .. It's an 06 model no warranty so I thought I could get some info here..this is what happend ... They were watching tv world series of all things and the tv made a normal sound . The sound it makes when it turns off they heard the click and no picture but sound is there and tv stays powered on... I'm planning on going over there this weekend to pull it apart and start checking fuses and what not ... Has anyone had this exact issue ?? If so what was the outcome .. I'm no tv guy by any means but I am a master hvac tech .. So I know my way around a meter and understand boards ... Any insight would be fantastic
    Thanks.... Mike
  • PlainBill
    • Feb 2009
    • 7034
    Re: LG 42PC3D-UD plasma problem
    LG 42PC3D-UD plasma
    Thanks.... Mike
    This TV uses hybrids on the Y and Z Sustains. These fail frequently. A quick and dirty test is to turn the TV on in a darkened room while a signal source is connected. If a very faint image is seen, especially in the lower right corner, it is almost certainly the Z-Sustain; if the screen is totally black it is probably the Y-sustain. After opening up the TV, check the fuses on the sustains. The one with the blown fuse is bad. In some cases the fuses will all be intact.
    The hybrid is expensive - about $40, and difficult to replace. Refurbished boards are available on eBay for about $50 and up.
    PlainBill
    • Sirmike
      • Nov 2011
      I had him do a quick Check for a image or a light source... And he said that it has no pic no image just black like its powered off... I guess I will have to get over there and open it up.. What makes the board hard to change ... Is there adjustments that need to be done after the board is replaced ... So it's not just replace part and be done ??
      • tw2005
        • Oct 2011
        • 6458
        I believe it's the replacement of the hybrid module itself on those boards that is difficult. Replacing the whole board assembly should be fairly straight forward.
        A collegue and I are currently attempting a repair of those modules on a LG Z sustain on a 50PX5D. Not going that well due to lack of experience and appropriate tools.
        • PlainBill
          • Feb 2009
          • 7034
          As TW2005 said, replacement of the module is difficult; replacement of the entire board is relatively easy, although adjustments are required. On the Z-sustain there is one voltage to be adjusted, On the Z-sustain it is more difficult. If I recall correctly, there are three adjustments and one requires use of a 200 Mhz oscilloscope. LG Electronics 'Plasma Quick Reference Guide' has the details.
          PlainBill
          • Sirmike
            • Nov 2011
            do these board run from 125.00 and so or like 400 and so on???
            if its like 125.00 for entire board ...i would just replace the board its still cheaper than buying any 42 inch plasma ...but ocilliscope ...im sol ...i have no clue on anything that has to do with that ....anyway i will post pics and check fuses this weekend or asap and report in ...thanks ....for giggles ...
            i have a pn50a650 samsung that i had a strange problem wanted to get some advise on,,,
            anyway about a week ago ....i was laying in bed ...this is my secondary tv for my beedroom...and out of nowhere ...i got this odor smelled like a cockroack was melting very nasty smell lasted a minute ....went away ...this happened about 3 diffrent times ...each time i could not pinpoint the smell coming from anything ...with my nose....well the other day i smelled it and my plasma turned off.....no led no power no nothing,,,will not turn on at all....now in hvac i have delt with alot of popping capacitors ...and they stink ....do you think thats what is wrong with tv ... i hear its comon id like to take it apart and see but ...i have some warranty guy coming to look at it on thursday....
            • PlainBill
              • Feb 2009
              • 7034
              First of all, the 'stream of consciousness' posts may be fine for a diary or blog, but are difficult to follow. I'm rapidly reaching the point where I will consider it a waste of time.
              Repair services are available for under $60 + shipping. Check the board number on eBay.
              As far as another TV, dead cockroach or otherwise, start another thread.
              PlainBill
              • Sirmike
                • Nov 2011
                I have wrote 8 different reeplies to this last post . Bill i Dont appreciate any of that .
                I dont care if it does bother you .
                This is my thread.
                and it just boils down to if it bothers you then dont be in here ...bye
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • renech
                  panasonic TH-42PC77U plasma television half screen problem
                  by renech
                  hello,
                  I hope someone on this forum can assist me.
                  I have a panasonic TH-42PC77U plasma television.
                  the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                  i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                  I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                  I have read some posts that suggest the problem is related to the boards on the left...
                  12-12-2022, 06:53 PM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                  Lenovo ThinkPad L15 + 3YOS Warranty Notebook L Specification for Upgrade or Repair
                  This specification for the Lenovo ThinkPad L15 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L15 + 3YOS Warranty boardview and L15 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-07-2024, 04:30 AM
                  Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) L Specification for Upgrade or Repair
                  This specification for the Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 Yoga + 3YOS Warranty boardview and L13 Yoga + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
