Samsung Plasma troubleshooting
  • thecrazy
    • Oct 2011
    • 6
    I have a 42 inch Plasma with samsung guts that was built around 2004
    I tested the voltages from the power board and the Vs, Ve and Vset voltages are wrong so i know that board is dead. Also, I read that the y sustain and the y buffers often go bad on these sets... my buffers look nothing like on
    http://blog.coppelltvrepair.com/2010...er-boards.html
    So I have no clue how to test them.
    At the moment I can power on the tv and the power led turns blue (from red while in sleep) and I can have sound on the tv but no picture at all (completely black).
    So i was thinking about switchin boards until the TV works, but im scared to blow up my replacement parts.
    If the Y buffers and/or the Y sustain board is defective and I replace the power board, can they blow up my replacement board?
    Also if anyone has a SM for a Prima ps-42d8c (my tv) or one of those similar TV bellow, i would appreciate it if you could send it to me.
    Maxent MX-42VM10 or AKAI PDP4294 and PDP42298ED, ESA PDP4294LV, ILO P42BSMT, MAXENT P4202YD04, Phillips 42FD9935/17, SAMSUNG SPN4235, SANYO DP42746
    Thank you!!!
  • thecrazy
    • Oct 2011
    • 6
    Re: Samsung Plasma troubleshooting
    Forgot to mention that the bad voltages comming out of my power board are all bellow what they should be. Can I then asume that nothing else was damaged by the power supply failling?
    • randtek
      • Oct 2011
      • 280
      • US
      Yes, bad X and or Y boards in plasma TVs can take out other boards. You should post what the voltage readings actually, not just that they are wrong or low. Inaccurate voltage readings are not much help in troubleshooting.
        Can you post a pic of your power board? The voltages can often be adjusted back to where they should be - on many TVs they drift out of tolerance and go bad.
        • PlainBill
          • Feb 2009
          • 7034
          A good source of service manuals / schematics is Elektrotanya. I'm not sure I'd put much time / money into a 7 year old plasma TV. Wine improves with age, plasma TVs don't.
          PlainBill
            PlainBill
            Just an 852x480 panel, too. Not HD. http://www.epinions.com/reviews/pr-P...nel_Television
            I would personally sell it on Craiglist to someone who is okay with spending a bit on an older TV.
            • thecrazy
              • Oct 2011
              • 6
              ouch, i thought this tv was 720p...
              so lets put a stop on this, Ill just scrap the tv
              thank you all for your help
              • strings
                • Apr 2013
                • canada
                Thank you!!!
                I have a Samsung PN42A450 plasma and trying fix it, I have no picture but have sound, I have changed the Y-Systain and the X-Systan still no picture can you help????
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Try starting a new post. No sense in digging up a year and a half old thread.
                    09-07-2024, 05:50 AM
                  • HarleyFool
                    Troubleshooting Samsung PN60E550D1FXZA Plasma TV
                    by HarleyFool
                    I have a Samsung 60-inch plasma TV, model PN60E550D1FXZA with factory remote. When cold, the TV will turn on and operate normally. After operating for longer than 30-60 minutes, if the set is turned OFF and then back ON, it will turn back ON, but there is no picture (screen remains black). I can confirm set is ON because I can hear audio from the speakers when I operate the VOLUME UP/DOWN control on the remote. If I allow the TV to rest (cool), it will eventually turn back ON with picture restored. That may take an hour or overnight.
                    I have removed the back of the TV and looked...
                    12-21-2021, 02:40 PM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
