Tv Sharp LC-40CF6022E
  • fanaticgames
    • May 2017
    • 138
    • italy
    Hi, this TV has a standby led on, but does not turn on.
    TV SHARP
    Model LC-40CF6022E
    Chassis TP.MS6486.PB711
    I need the memory dump or firmware. Can someone help, thanks
  • fanaticgames
    • May 2017
    • 138
    • italy
    Re: Tv Sharp LC-40CF6022E
    I found a Chassis TP.MS6486.PB711 motherboard but from another sharp model, at the hardware level it seems identical, can this card be swapped?
    anyone have experience with this?
    • Mirenia
      Samsung UEMU6199U - no Standby - bad Firmware?
      by Mirenia
      I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
      Voltages on the power supply board is okay. Backlight test is also okay.
      I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
      So I think my TV has exactly this issue.
      Can someone please fix the dump?
      And how do you do that?
      As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
      05-12-2025, 06:13 AM
    • raileanu
      TV SHARP LC-26P50E KD186 QKITPD186WJN3 (WE015169S) need working firmware dump set
      by raileanu
      Hi.
      Please if someone help me with a functional firmware dump for this KD186 QKITPD186WJN3 (WE015169S) motherboard from TV SHARP LC-26P50E.
      I think this motherboard it is found in several models.
      What I need is firmware for the NOR chip SST39VF1682 (IC2003) and for the two EEPROMs 24C64 (IC2002) and 24C32 (IC4501).
      I am especially interested in the NOR firmware because I think it has problems.
      The TV initially came only with the red STB LED on and it did not respond to any commands.
      I checked the power supply...
      07-11-2022, 10:07 AM
    • AustinComputerDoctor
      Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
      by AustinComputerDoctor
      I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
      I see backlite is active,
      but I cannot get the screen to return back to menus , etc
      This is all after replacing the mainboard...
      any assistance is greatly appreciated.
      03-25-2024, 12:43 PM
    • SJX1290
      Sharp 50BL2AE stays on standby
      by SJX1290
      Hi,have Sharp 50BL2AE which is not powering, stays on stand by, White control led is permanently on, signal from remote is coming on board as well from power -mutifunctional button on back side. All power voltages seems to be ok. Backlight checked, working..
      Any ideas?
      12-10-2024, 01:17 AM
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
