Samsung LNS3241D (PICS of Problem)
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung LNS3241D (PICS of Problem)
    Good job of troubleshooting. Different classes of inputs follow different paths. This definitely points to a problem with the main board. I'd try checking the voltage regulators on the main board - there may be a bunch of them.
    PlainBill
    • illtww
      • Aug 2010
      • 19
      I hate to revive this thread but I am trying to get my set up and running for the B-Ball games tonight...
      Any thoughts on it being a cold-solder joint by the transformer like on the LN-S4041D!?
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        What's the problem now? Pictures maybe?
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          Originally posted by illtww
          I think I spoke to soon. The tv now does some weird things;
          If I am watching Football on espn and the game is on it seems to work ok but when it goes to a commercial and there is more black on the screen than white the whole pic vanishes for a sec then comes back when the games starts!??! What the?
          If i turn on Pic-In-A-PIC mode the screen never shuts off but then I ahve to deal wiht this big block in the way for the screen.... UGH!
          I am guessing I need to find another motherboard?
          Thoughts?
          OH, I SEE..... This is the time where you might want to buy a new TV. Too much BS with this one. Get a cheap 32 plasma and save the time if you need it to work sooner than later.
          • illtww
            • Aug 2010
            • 19
            If I can get it to stay on long enough to change to PIP mode the tv will run forever and not blink the picture on-and-off at all. The minute I take it off it seems to have an issue.
            Takes about 5-10mins (after first start-up) for the video to stay on long enough to change to PIP mode..
            Is this a cold solder joint?
            Also, IS there a what to cross-reference which motherboards are actually compatible whit my set. AKA ones form (37, 40" models etc...)
            I can get some pics of the problem and the board if that will help.
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
              09-06-2024, 11:40 PM
