Nikon Coolpix P520 - Not working properly | Short
  • arpii
    • Oct 2021
    • Hungary
    I got a Nikon Coolpix P520 in a defective condition, few weeks ago. The battery is a 3.7V 1000mA Li-Ion battery, it was almost completely discharged.
    The symptons (back in time):
    -Not starting
    -Not charging
    Disassembled, then found few things. There was a short on the line of the battery feed rail and the USB charger port's fuse was also wrong.
    Fed 3.7V to the battery line with a bench PS and a small ceramic capacitor warmed up next to the battery positive point. Just removed this cap and confirmed, it was bad. There is no any sign or schematic available for this model, so decided to do not replace this cap, just left as it is. Also put a temporary connection to make the USB working (I dont know the fuse value which was there, and to be honest dont care).
    Now the camera is able to start, but not all the way and not all the time.
    In example:
    -If everything is assembled, then its sometimes starts, sometimes not starting, even if there is nothing turned on, consuming above 1Amps, and the LCD 32 pin connector and the wire itself heating up very quickly.
    If its starts for some reason, there is absolutely fine picture on the LCD screen, but few moments later the screen disappears and become a black screen on the LCD, with background light.
    -If i go for deattach the LCD from the end of the 32pin cable, but the cable still connected to the board, still the same. Wire heating up, in OCP the PS buzz, as it's a short in the circuit.
    -If i remove the connected 32pin cable completely from the board, when I feed with power, its consuming few hundreds of milliamps for 1-2 seconds then return to 0, what should be the normal behavior.
    In this case, the camera fully functional, just I dont have LCD, so can see the pic in the hole (you know), but Zoom fully working, exponation button, etc. what I just tried out.
    The question now, how to get the root cause?! (Any idea would be really great, because I'm stucked now)
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
  • Stephen
    MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
    by Stephen
    I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
    02-06-2025, 12:03 PM
    LENOVO ThinkStation P520 ThinkStation P W-2133 Specification for Upgrade or Repair
    This specification for the LENOVO ThinkStation P520 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation P520 boardview and ThinkStation P520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-12-2024, 02:15 PM
    LENOVO ThinkStation P520 ThinkStation P W-2275 Specification for Upgrade or Repair
    LENOVO ThinkStation P520 ThinkStation P W-2225 Specification for Upgrade or Repair
