I pull quite a few DC power bricks from the bin at work, mostly out of curiosity and for parts. I've never seen one that doesn't specify a static output voltage before. I tested it at 20v DC without any load. I plan on opening it up for inspection since it has a date code from 1996-97. I assume some bad caps but who knows. Also, it has the very common 5.5x2.1mm barrel jack on the end.
Variable DC power brick?
Last edited by jayjr1105; 06-02-2021, 12:07 PM.--------------------------------------------------------------
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%Tags: None
Ryzen 3600x
FX-8802 Iron
Re: Variable DC power brick?
So much for a 45w limit. It's an ambitious little supply... also not super efficient...
Ryzen 3600x
FX-8802 Iron
