Samsung Soundbar No Power
  • Storyteller12
    • Jun 2020
    • 625
    Hi, need some help here.
    I have this smps for a n850 Samsung Soundbar that gets no output voltage.
    I have check everything and found that I'm getting 390v from the main caps on the hot side. However there is an IC that needs 300v to turn on. There are (2)513 smd resistors in parallel that are supposed to drop the voltage from 390v to 300v. However the resistors drop the voltage to 190v through the first resistor and to 25v through the second.
    I took both resistors out of circuit and both measure good 50kohms.
    I plan on replacing them anyways but not sure that will solve the problem since they tested good.
    Any thoughts or suggestions would be greatly appreciated. In the last picture I highlight the path to the resistors and ic I was talking about
    Thanks in advance
  • R_J
    • Jun 2012
    • 9582
    Re: Samsung Soundbar No Power
    How are you getting 390 volts on the main caps? I don't see a pfc circuit and the caps seem to be straight off the bridge rectifier, so it should be around 160vdc
    The ic needs a VCC voltage, this will be across the small electrolytic next to the mosfet heatsink, If this cap is bad, the circuit will not start up.
      • Jul 2011
      • 6059
      I would first replace the 10uf@50 volt cap and go from there but really you should just replace all the caps good quality caps and go from there except the two main filtering caps unless they are leaking then replace all of them
      • Storyteller12
        • Jun 2020
        • 625
        Thanks for all the reply’s. R_J you were right about the voltage. My multimeter was acting up and had to replace it.
        Turns out it was the ic that was bad and stuck open. I have a new one ordered and just waiting for it to arrive.
        The soundbar is fairly new. Only 2 years old so I don’t think the Caps need replaced but since I have it open I might as well right? What brand caps do you recommend?
        Thanks again for the help
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
          Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
          This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 06:20 PM
