Wine Enthusiast wine cooler, no power. Model # 272 03 29
  • redwire
    • Dec 2010
    • 3910
    Re: Wine Enthusiast wine cooler, no power. Model # 272 03 29
    It's so you can take out the board and put it back in, without screwing up the connectors. Did you notice four are all the same 2-pin connector and can get mixed up!
    I use a felt pen and put a stripe or dot (or two), or you can use masking tape etc to label the wires - CN1 (connector 1) etc. FAN, TEMP SENSOR, LEDs, PELTIER module etc.
      • Jul 2011
      • 6039
      Originally posted by ajsterr4
      I'd like to do it on a table, why would labeling wires help me?
      The reason for doing this is IF you have a bunch of wires that are the same exact color or IF you have connectors have the same profile
      How will you know which wire OR which connector went where
      If you hook wires or connectors in the wrong place at a minimum nothing will happen or the hole board could go up in flames or blow fuse or circuit breaker
      This is the reason for labeling wires or connectors and take pictures
      I hope this helps you understand why I made this comment before
      I do this most of the time when I work on board unless the board is marked with the wire number or jumper number and even then I will take pictures of the board any way
      • rivera2j
        • Jul 2021
        Hi. I am new to this. Obviously i have the same problem as many of you have with this board ("c-110-cd"). I've seen a number of boards that looks like they can do the same as this one ("c-110-cd") Has anybody replaced the ("c-110-cd") with a FX-102?
        Thanks!
        • rivera2j
          • Jul 2021
          https://www.aliexpress.com/item/1005...68eeffd6e6fd-0
            • Jul 2011
            • 6039
            I would recommend that you replace all capacitors that are 100uf and lower unless you have a ESR capacitor tester and if you can compare to a new one is even better
            If you decide to buy a new switching power supply for this device I would still recommend that you recap this this switching power supply if it has non brand name capacitor manufacturers
            • magik20
              Wine Enthusiast 170 Bottle N'Finity Wine Cellar Model # 273 02 70
              by magik20
              I'm hoping someone might be able to offer some guidance on repairing a Wine Enthusiast N'finity 170 bottle wine cellar, model 273 02 70.
              I recently acquired this unit for free via Facebook Marketplace, hoping to fix it up as a gift for my wife. I have some basic electronic skills (comfortable with a multimeter, basic soldering, identifying components) but I'm definitely not an advanced technician.
              The main challenge is that when I picked up the unit, the main control/power board had already been removed and the previous owner said it needs a...
              04-30-2025, 04:46 PM
              HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
              This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              09-06-2024, 05:27 AM
              HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
              This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            • edugimeno
              Wine cooler flickers at startup and doesn't cool enough
              by edugimeno
              Hi there!
              I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
              Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
              Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
              When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some...
              03-01-2025, 04:51 AM
