Cooler Master RS500 no load no party
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    I repaired a RS500 (bad caps on +5 +3,3 and +5vsb) and experienced an unexpected behaviour by the psu. I usually test if the psu starts connecting the green wire to ground. This one shuts down immediatly, the fan spins just a bit. Connecting a small load, an hd, it runs good.
    It's the first time I see something like that. Do I have to expect this as normal for the future or am I missing something?
  • dmill89
    • Dec 2011
    • 2534
    Re: Cooler Master RS500 no load no party
    Some PSUs won't start (well really keep running for more than a fraction of a second) without a load. AcBel units are known for this. Which specific model PSU do you have (should be something like RS500-xxxx-xx)? There were several different sub models of the RS500, some of which were made by AcBel.
    • Dumah Brazorf
      • Jun 2013
      • 179
      • Italy
      Rs500-pcap-a3
      The board is a PC7013-000G PCB1... built by AcBel!
      • Uranium-235
        Scythe Fuma 3 or Cooler Master MA620M
        by Uranium-235
        I have a 5900x to replace my 5800x (actually a fair bit of performance difference). It came with the CM. I can't actually find any article of a direct comparison between the two. The Fuma has a Higher TDP but the CM looks to have a more solid build. Fresh AS5 either way.
        Scythe Fuma 3
        100.00%
        1
        0%
        0
        11-01-2025, 02:08 AM
      • Guilty_2121
        cooler master rs-750 load problem
        by Guilty_2121
        my power supply shuts off under load, starts with out problem, the i tried to play game or benchmark, pc shuts off. I check the caps they looks good and looks like no weak solder. what shout i suspect?
        model: cooler master rs-750-amaa-b1
        04-09-2021, 02:21 AM
      • AJ847.63e
        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
        by AJ847.63e
        Hi Folks,
        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
        05-06-2025, 10:37 PM
      • Topcat
        Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
        by Topcat
        This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
        ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
        03-12-2022, 10:58 PM
        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-12-2024, 02:20 PM
