MGE Ups Ellipse 650
  • Vaggelis
    • Jul 2015
    • greece
    MGE Ups Ellipse 650
    I am looking a schematic electric diagram for the board of a Mge Ups Ellipse 650.
    I would appreciate any kind of help.
    Best regards,
    Vaggelis.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5096
    • New Zealand
    Re: MGE Ups Ellipse 650
    Have you tried places like elektrotanya.com?
    It may also help if you can describe the problem you have and what you need the schematic for... sometimes things can be fixed without the schematic, but we would need to know what the fault is and you would need to post photos of the board etc.
    Also, sometimes the same boards are used in several brands or models so if you post a photo of it someone could recognise it and be able to find the schematic under another name.
    -David VanHorn
    • hs5424
      Dynacord powermate 1600 block diagram.
      by hs5424
      Hi All,
      I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
      The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
      07-31-2025, 01:35 PM
    • SilverbackITGuy
      Asus ROG Strix G17 , Identifying a part number from the boardview diagram ID
      by SilverbackITGuy
      First of all, I hope I got this into the right section. Apologies if I did not.
      I was working on my Asus ROG Strix G17 (2021) G713QM-RS96, and I guess I pre-heated the board too much replacing the DC Jack and one of the small parts came off. I looked for it on my soldering mat, and it was nowhere to be found. So now, the laptop is powered from the new DC Jack I installed, but it will not charge the battery from that jack. Only powers the hardware.
      I looked at the boardview diagram in another post for the G713QM, and it looks like the diagram displays it as X450, a 4 contact...
      11-18-2025, 07:23 PM
    • gabri2211
      I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
      by gabri2211
      hello everyone, I'm looking for the wiring diagram of this led monitor.
      the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
      I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
      I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
      thanks to those who will answer
      12-10-2024, 04:37 PM
    • sheffieldyorky
      ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
      by sheffieldyorky
      Hey there people
      While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
      This is what I tried, but not in any order.
      Google
      YouTube
      BIOS
      Command Prompt (administrator privileges)
      On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
      10-25-2025, 02:22 AM
    • e-repair
      Broken connector on an electric boat power steering
      by e-repair
      Hey, i have to repair an electronic board on an electric power stearing. the package was damaged during delivery and the connector was broken. but i can't find a part. the connector is the same BUT reversed as fiat power steering. I searched on digikey, mouser and aliexpress and i can't find any part similar. it's an uflex electric power steering, but i don't have more reference on the power steering block. if needed, i can buy any complete part just to recover the conector on the board and put it on this board...
      09-24-2025, 07:30 AM
