CyberPower 1350/1500VA AVR UPS
  • Steve_fromKS
    Does anyone have a schematic for these CyberPower AVR UPS's? Thank you... Steve_fromKS
    • Jul 2011
    • 6039
    Post some very in focus pictures so you can read the print on the board and components
    Please post some pictures of both sides of each board
    We might be able to help you with this repair
    • Sean Devine
      Cyberpower 1285AVR (CP1285AVRLCD) reporting wrong battery voltage?
      by Sean Devine
      UPS turned off one night and it seemed that the 3 year old batteries gave out.
      Replaced with a new pair, but the UPS software claimed the battery voltage was only 18 volts and needed to charge. After 24 hours, the UPS claimed only 60% charge and 20 volts (although FWIW, my meter sees 27v).
      ...then I found various Cyberpower threads here with some guidance on what to check.
      C1 (22uF) tested at 2, so I replaced that.
      Put it all back together and didn't see a change on the reported battery voltage. Although, I did run the quick battery diagnostic...
      03-03-2025, 08:23 PM
    • bohaboha
      Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
      by bohaboha
      Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
      anyhow i couldn't t read anything else
      the backlight is on strong and the screen does not get dark or very dark but no pictures
      the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
      01-02-2025, 08:04 PM
    • valvashon
      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
      by valvashon
      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
      11-24-2024, 12:08 PM
    • mattsbone
      Canon W8400p Printhead BC-1350 EEprom Dump Help.
      by mattsbone
      Trying to fix a broken w8400 canon printer with a BC-1350 printhead.
      I believe the BC-1300, BC-1400, BC-1450, BC-1350 are all the same printhead with the difference being the data in the EEprom.
      I have a dump of a BC-1350 printhead but not sure if it is correct, Is there anyone on this forum that has any information that could help me out?
      00 3E 06 65 9C 04 00 0F 56 62 3C 10 2F 2E 2D 2D 2E 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 11 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00...
      03-05-2023, 02:41 PM
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
